Behringer Shark/LR Baggs Acoustic DI
peterbright
Posted 2004-02-05 7:36 AM (#195690)
Subject: Behringer Shark/LR Baggs Acoustic DI
Any one with a short course on using these two in tandem and appropriate settings...I could use the education.
Is it better to experiment with one at a time first?
Posted 2004-02-05 12:03 PM (#195691 - in reply to #195690)
Subject: Re: Behringer Shark/LR Baggs Acoustic DI
The single most important thing about using the Shark is getting the input gain right. It tells you how to do this in the manual. From my exerience it's best to set the feedback filters with the narrowest bandwidth, steepest notch & low sensitivity. It will take a little longer to lock on to the feedback but it won't mess with your tone. Unless you use drop tunings set the high pass filter at 82Hz. Use the Shark after the Baggs.
As for the Baggs, start with the controls flat, and your amp or console flat, adjust the guitar's onboard EQ till it's as good as it will get (avoid big cuts or boosts, keep them to 2-3dB) Then fine tune from the Baggs.
Posted 2004-02-05 1:43 PM (#195692 - in reply to #195690)
The only thing I would add is to setup your guitar without the Shark inline first. Get the maximum volume/eq of the system setup in the clear and see where the real threshold is, best sound and such. I do this because a lot of times the EQ of the system will be way off, causing you to be compensating for things that may be an easy fix at the board or otherwise. It's just a precaution to have the best sound you can, than bring on the tools to keep it that way.
peterbright
Posted 2004-02-05 2:22 PM (#195693 - in reply to #195690)
Thanks much for the info. I have notch filters on the preamp (OP40) & the power amp (Peavy Ecoustic 112). Should I not use those when using the Shark/Baggs combo?
Posted 2004-02-05 2:59 PM (#195694 - in reply to #195690)
I've found when using the Shark I can leave all other feedback tools off
Posted 2004-02-05 3:43 PM (#195695 - in reply to #195690)
Oh yes, with the Shark you would not need anything else. By "Tools" I was referring to the Shark. Get everything prestine without it, then kick it, set it up if necessary, and no worries.
peterbright
Posted 2004-02-05 8:35 PM (#195696 - in reply to #195690)
Thanks guys, this info will save me a lot of experimentation time.
Posted 2004-02-05 10:03 PM (#195697 - in reply to #195690)
i bet paul t can't leave the compressor off
Posted 2004-02-06 3:47 AM (#195698 - in reply to #195690)
Oh yes I can, the internal compressor in the Shark isn't great. I have a DBX compressor in my acoustic rig.
