Strings on new Ovations
RiffD
Posted 2007-04-08 4:28 PM (#106425)
Subject: Strings on new Ovations
March 2007
Anyone know what they're putting on new Ovations? I'm replacing my 6778LX strings, don't like them, but thought I was putting on lighter strings with some Elixir Polywebs custom light. Turns out the stock strings are *much* lighter.
:confused:
Posted 2007-04-08 4:38 PM (#106426 - in reply to #106425)
Subject: Re: Strings on new Ovations
I may be wrong, but I believe that D'Add.EXP Lights is what's coming on guitars from the Factory . . .
Old Applause Owner
Posted 2007-04-08 4:43 PM (#106427 - in reply to #106425)
July 2003
Stock strings from the factory are D'Addario EXP .012"-.053".
Roger
RiffD
Posted 2007-04-08 5:11 PM (#106428 - in reply to #106425)
March 2007
Wow...these must be different then. The low-E on the Elixirs is .052, and it's substantially fatter than what's on there (which if it were .053, couldn't tell much difference).
Thanks!
Randy22
Posted 2007-04-08 7:25 PM (#106429 - in reply to #106425)
April 2003
I put Elixir lights on, and they seemed tight and hard to play. Switched to Elixir extra lights, and they're good, although the E (.047) seemed a little floppy.
Also, while I've been happy with the strings put on from the factory (EXP lights), when I went to put on regular D'Addario lights (EJ16) they seem heavier than what came from the factory. Are EXP lower tension that regular D'Addario maybe?
Posted 2007-04-08 8:27 PM (#106430 - in reply to #106425)
exp 12-52
mtnbikerfred
Posted 2007-04-08 8:58 PM (#106431 - in reply to #106425)
No.
But I would suggest you get a cheap set of "slide rule" calipers to verify the gauges of your strings
Yak
Posted 2007-04-08 9:15 PM (#106432 - in reply to #106425)
In my opinion, anything lighter than 11's sounds too thin. There has got to be balance between tone and playability. RiffD, try some of the Ernie Ball Super Slinky's (2148) 11-50. As named, they actually are pretty "slinky". More so than some of the other brands like D'addario(EJ26).
Ovations usually come with 12-53's from the factory. If you bought it with thinner strings, than someone changed them out.
Old Tele man
Posted 2007-04-10 9:12 PM (#106433 - in reply to #106425)
...when I asked Ovation, they said the factory-installed strings on my AE68 Viper were D'Addario EXP17 (0.013"-0.056").
