Glue for Nut?
leonardmccoy
Posted 2017-04-11 11:15 AM (#533624)
Subject: Glue for Nut?
December 2015
The bone nut of my Legend L717 (1990) has come loose for some time now (it was only lightly attached before), and while it's overall not a massive problem, it's bothersome when changing strings all at the same time.
What kind of glue would you recommend for fixated the nut at the headstock again? Thanks.
Edited by leonardmccoy 2017-04-11 11:28 AM
Thunderbolt
Posted 2017-04-11 11:27 AM (#533626 - in reply to #533624)
Subject: RE: Glue for Nut?
April 2014
this works
(db58ef49-c69d-4019-af70-7244fb05c058_400.jpg)
Attachments db58ef49-c69d-4019-af70-7244fb05c058_400.jpg (10KB - 2 downloads)
leonardmccoy
Posted 2017-04-11 12:43 PM (#533627 - in reply to #533624)
Subject: Re: Glue for Nut?
December 2015
Thanks a ton. Just ordered it via Amazon.
jay
Posted 2017-04-11 1:05 PM (#533628 - in reply to #533624)
January 2009
A little dab of Elmer's would work just fine.
Posted 2017-04-11 1:49 PM (#533629 - in reply to #533628)
jay - 2017-04-11 12:05 PM
Yes. I used Elmer's carpenter glue and it's held for years. It's not bone, but I don't think that would make much difference. It doesn't take much to hold it.
DanSavage
Posted 2017-04-11 1:54 PM (#533630 - in reply to #533629)
June 2012
Yeah, you don't want to use more than just a couple of drops of glue so that if/when it needs to be replaced in the future it can be popped loose with a gentle tap.
Posted 2017-04-11 3:07 PM (#533636 - in reply to #533624)
I thought of what Dan just said as soon as I hit "Submit". You don't want anything that will tear up the guitar if you need to replace the nut again.
leonardmccoy
Posted 2017-04-11 4:10 PM (#533637 - in reply to #533624)
December 2015
Good point, I'll make sure to use it sparingly, just to fixate the nut a little in the middle.
leonardmccoy
Posted 2017-04-18 7:40 AM (#533744 - in reply to #533624)
December 2015
It all went down well. I could also eliminate some sharp overtones on the high E string by slightly grazing the nut slot with a very fine needle, and I glued together a broken bar stool on the side as well. Gosh, I've always loved me some Titebond.
Edited by leonardmccoy 2017-04-18 7:42 AM
