New 8 String Cloud Nine
Bear
Posted 2014-12-31 10:12 AM (#504313)
Subject: New 8 String Cloud Nine
October 2013
Hi
Just picked up a Cloud Nine 8 String
Does anyone have a suggestion on strings as I need to change them out.
Do I buy a 12 string set and just use the ones I need?
And does anyone know what gauge would be best?
Thanks Bear.
stellarjim
Posted 2015-01-02 10:30 PM (#504397 - in reply to #504313)
Subject: Re: New 8 String Cloud Nine
Good luck with that one Bear. I'm still trying to figure out the first 6 strings.
I very much doubt you would buy a 12 string set because a typical set of 12er strings use an octave string paired with a standard string. Your 8 string (I'm assuming here) probably uses 2 additional bass strings. So I'd guess you should check with www.juststrings.com or and equivalent site.
Posted 2015-01-03 1:28 AM (#504402 - in reply to #504313)
Regular 6 string set with the two doubled strings as octaves....or whatever a standard 12 string would have for those two strings. Emulates the sound of a 12 without the extra 4 strings.
Posted 2015-01-03 12:50 PM (#504411 - in reply to #504313)
It seems to be a variant on the Roger McGuinn 7-string (octave GString added) by also adding an Octave D string. Probably you use a regular six string set and add a 9 and a 14 to the mix. I'll bet it sounds real jangly.
AstroDan
Posted 2015-01-03 1:06 PM (#504412 - in reply to #504313)
March 2010
It uses octave D and G strings.
Sounds nice and looks awesome!
Bear
Posted 2015-01-05 10:59 AM (#504443 - in reply to #504313)
October 2013
Still not getting it as Astro Dan is correct it is set up with two strings ovtave up on the D and G strings in the center.
It sounds awesome. Like a blend 6/12 string without having to fight 4 extra strings.
But not sure what to buy.
SOBeach
Posted 2015-01-05 12:17 PM (#504446 - in reply to #504443)
April 2010
Bear - 2015-01-05 11:59 AM Still not getting it ... not sure what to buy.
I'd email the manufacturer and ask 'em for their recommendations.
http://www.cloudnineguitars.com.au/a/Custom-Guitars
Posted 2015-01-05 1:20 PM (#504450 - in reply to #504443)
Bear - 2015-01-05 8:59 AM Still not getting it as Astro Dan is correct it is set up with two strings ovtave up on the D and G strings in the center. It sounds awesome. Like a blend 6/12 string without having to fight 4 extra strings. But not sure what to buy.
stonebobbo - 2015-01-03 10:50 AM  Probably you use a regular six string set and add a 9 and a 14 to the mix.
Posted 2015-01-05 3:55 PM (#504452 - in reply to #504313)
I declare Bobbo the winner by 16 minutes...
