NEW in 2026Searches both the Ovation FanClub and Ovation Tribute websites
OP24+
Jump to page : 1 Now viewing page 1 [25 messages per page]
I recently picked up used Celebrity Deluxe with the OP24+ pre amp....
The electronics are OK however, the high E string is not as loud as other strings. It is a very noticeable difference and I will not use it in a performance. I've not removed the saddle to inspect the pick up but intend to do so... Any other ides would be appreciated. Thanks
Posted 2013-08-03 3:42 PM (#473822 - in reply to #473817) Subject: Re: OP24+
Look to see if there are any shims under that saddle.
It is possible that there are, and that it is not correctly placed under the end of the E string.
Posted 2013-08-04 11:50 AM (#473830 - in reply to #473817) Subject: Re: OP24+
The pickup and saddle are One Unit. (If it is not, the pickup has been changed) If you have a thin saddle the shim would be under the pick-up/saddle unit. These will come apart, but try to avoid that. There are no user-serviceable parts in there, but it will go back together. There is also a wider saddle... It is also a one-piece unit. Here is a video from Ovation...
Posted 2013-08-13 2:10 PM (#473981 - in reply to #473817) Subject: Re: OP24+
My photo did not attach but there is a copper shim and the 6 magnets which are embedded in what looks to be silicone.......
A picture would have been easier....
Posted 2013-08-13 3:02 PM (#473982 - in reply to #473817) Subject: Re: OP24+
If you have a piece that fell completely out, and is not attached to anything...
That would go under that copper thing that is attached to the wire.
Now...
I would think that the side with the 6 magnets (piezos) would go towards the copper piece that is attached to the wire... If not, it would go the other way... right?
[time passes... many minutes later...]
Okay... I just dissected a perfectly good CP-100 pickup.
Under the copper slab that is attached to the wire I can see a slab of silicone with 6 rectangular copper-colored thingies.. Those are the piezos.
I did not remove them from the silver housing because this pickup works, and I want it to continue to do so.
So, the side with the rectangular copper thingies goes under the copper slab, facing Up.
If all else fails, contact Ovation at askus@ovationguitars.com
or call 800-552-4681
There you can order a new CP-100 saddle... in White or Black.
Now that I helped you destroy your guitar pick-up...
Anything else that I can help you with?
Posted 2013-08-13 3:19 PM (#473984 - in reply to #473817) Subject: Re: OP24+
Thanks for the reply... I have a message in the system, we'll see.... If I have to order a new one no problem...
Wish I could get you a picture......
Again, about 3:45 into the vid you sent me, a copper shim pops out of the assembly which indicates it goes on top.... strange.... Thanks again...
