Pre Amp/tuner is stuck! :(
Rocketjsqurl
Posted 2009-12-19 3:49 PM (#386324)
Subject: Pre Amp/tuner is stuck! :(
August 2008
I replaced my 9V battery on my Balladeer preamp/tuner and it didn't seat right and now is jammed. I can't seem to pry it lose. Any suggestions? I appreciate it....Merry Christmas
Posted 2009-12-19 4:21 PM (#386325 - in reply to #386324)
Subject: Re: Pre Amp/tuner is stuck! :(
Which PA is it?
Is this the same Balladeer you had issues with before?
<Hold on a while, help is on the way... >
Rocketjsqurl
Posted 2009-12-19 4:52 PM (#386326 - in reply to #386324)
August 2008
Yes. Seems a little snake bitten.
Rocketjsqurl
Posted 2009-12-19 6:00 PM (#386327 - in reply to #386324)
August 2008
Its an Ovation op Pro Pre Amp
Posted 2009-12-19 6:03 PM (#386328 - in reply to #386324)
Try gently pressing down on it at both ends and wiggling it to see if it will set properly. If not, try inserting a thin blade between the end with the release button and the can, and gently pry up on it.
Gently.
Rocketjsqurl
Posted 2009-12-19 6:08 PM (#386329 - in reply to #386324)
August 2008
Thanks PB...I'll give it a try
Rocketjsqurl
Posted 2009-12-19 6:20 PM (#386330 - in reply to #386324)
August 2008
did it! Thanks...I need to be more carefull when reseating it. :)
Merry Xmas to you and your family
Posted 2009-12-19 6:21 PM (#386331 - in reply to #386324)
Same to you.
Fridave
Posted 2009-12-19 6:21 PM (#386332 - in reply to #386324)
February 2008
If you manage to get it out try loosining the screws that hold the can (pick up holder) in a little bit, I had one that was troublesome getting out and a little counterclockwise twist of the can mounting screws did the trick. Good luck!
