GK-2 on Ovation
First Alternate
Posted 2006-05-24 9:09 AM (#253800)
Subject: GK-2 on Ovation
May 2005
I've used a GR-33 and a Strat in the past, so I'm familiar with synth use. I am, however, toying with the idea of mounting a GK-2 on my 1869 for gig use, similar to what DiMeola does. For those who have done this, my questions:
How do you mount the pickup under the strings to get it close to the strings and the saddle, and;
What do you do about a case, given that you can't close the case lid over the top mounted portion of the pickup?
Thanks.
matrix
Posted 2006-05-24 9:26 AM (#253801 - in reply to #253800)
Subject: Re: GK-2 on Ovation
February 2006
I've never done that(yet), but I think a gig bag would work for a case.
Posted 2006-05-24 9:37 AM (#253802 - in reply to #253800)
I've done it with a 1517D Ultra. Yes, a gig bag is your best bet.
Mount the GK-2 as close to the saddle as possible without touching it, using the 2 sided mounting tape to avoid making holes in the top. Follow the Roland instructions for aligning and adjusting the pickup so you get even levels across all strings.
Posted 2006-05-24 9:40 AM (#253803 - in reply to #253800)
ovation used to offer it as an option.
double sided tape next to the bridge will work
LeStrange1
Posted 2006-05-24 10:55 AM (#253804 - in reply to #253800)
I pasted this from my past post.
I retro-fit my Ovation Elite 1778T with the Roland GK-2A Divided Pickup and it is plugged into my Roland VGA-7 Amplifier. The bracket does not fit the Ovation but you can do away with it and just use the velcro to adhere the control of the pickup to the top of the guitar. I used the double stick tape to install the pickup near the bridge. (measure carefully for perfect intonation) I haven't had a problem with the control of the pickup moving but I have posted the question as to whether or not ot would damage the top to install the pickup permanently by using the two screws. I haven't really found an answer to that yet so I continue to keep the tape. Its very sturdy and hasn't come off yet.
One problem I ran into was closing the case. I took a light hammer and tapped the area of the lid where the pickup control is when you shut the case and made a perfect sized indentation so I could close it. It looks great, you can NOT tell! It CAN be done and the finished product will rock your socks OFF! I'd have it NO other way. Good luck!!!
Posted 2006-05-24 10:57 AM (#253805 - in reply to #253800)
The only damage from permanent installation would be the screw holes.
LeStrange1
Posted 2006-05-24 10:58 AM (#253806 - in reply to #253800)
Yes, I don't think I'll ever use the screws because the double-sided tape has held now for almost 2 years. No problems.
First Alternate
Posted 2006-05-24 12:35 PM (#253807 - in reply to #253800)
May 2005
OK, I got it installed. Using the double sided tape is much more painstaking than the screws and springs I used on the strat, and although I couldn't get the pickup as close to the strings as it was on the strat, I compensated by adjusting the string sensitivity on the bass side. I like the idea of hammering the inside of the case to make room for the control box. Clever.
Thanks to all.
NostrAdamas
Posted 2006-05-24 1:00 PM (#253808 - in reply to #253800)
October 2004
I had mine installed from the factory in 95 and had to remount it again and I use a grey window puddy unlike the double stick tape that will leave a blemish when removed.works for me.just cant beat a fretless bass on the low e and a with a string patch hovering underneath its bloody HUGE!!
www.guitarsoffire.com
