UK Noob
therealche
Posted 2008-11-20 3:37 PM (#10880)
Subject: UK Noob
November 2008
Hi just thought id introduce my 1627 ( serial no 170821) which I got off fleabay a few weeks ago. Its had a hard life but after an hour or so with a soldering iron, drill and pop riveter I got the electrics going, though Im still waiting on new knobs to relace the cracked originals.
It has the usual scratches and chips but the worst bit is a ham fisted previous owner tried to fit a strap button to the base of the neck
That ones going to be a test of my DIY skills!
The action is a bit high so I beleive from what Ive read that I need to remove some shims from under the bridge. Any advice of the best way of doing this without damaging the pickup. Im sure you guys have the knowledge
Thanks
Neil
therealche
Posted 2008-11-20 3:39 PM (#10881 - in reply to #10880)
Subject: Re: UK Noob
November 2008
Wow those pics are HUGE!!!!! Sorry guys Im used to forums that resize automatically!
Neil
G8r
Posted 2008-11-20 3:56 PM (#10882 - in reply to #10880)
Welcome Neil. That qualifies for BFLG status (Bottom Feeders Luthiery Guild)!
The easiest way to get at the shims without damaging the pickup is to push the pickup wire upwards from inside the bowl. That'll raise the saddle/pickup assembly (what we call the PUassy) enough that you can the grab it and finish lifting it away from the bridge. The shims are in the saddle slot under the PUassy. There are two plastic doohickeys (another technical term) on either side of the saddle that hold the whole thing in place by pressure. You can feel the pins for those from inside the guitar, so push those up first before you try to remove the PUassy.
Post after pictures & best of luck!
Steve
Posted 2008-11-20 3:57 PM (#10883 - in reply to #10880)
July 2002
Remove the strings, get a small pair of needle-nose pliers and carefully pull up the 2 tabs on either side of the bridge assembly. Place your hand inside the sound-hole, find the small cable that is attached to the bottom of the pickup and slowly push it up. The saddle assembly will rise up out of the bridge. Any shims will be under the saddle assembly. Remove the shims, replace the saddle assembly, and re-insert the tabs.
(Welcome to the OFC.. :) )
Posted 2008-11-20 4:25 PM (#10884 - in reply to #10880)
You'll fit in just fine, che.
Not so sure about your pics tho...
Posted 2008-11-20 4:38 PM (#10885 - in reply to #10880)
Neil
We don't go for that Hi-Tek crap!
Welcome Neil
Posted 2008-11-20 5:00 PM (#10886 - in reply to #10880)
Nice! Welcome.
Posted 2008-11-20 5:34 PM (#10887 - in reply to #10880)
Welcome! As our 6,712 member, you have won the prize of the day!!!
Free picture resizer...
Oddball
Posted 2008-11-20 8:12 PM (#10888 - in reply to #10880)
March 2007
Ouch, Achilles died of an injury like that. Other than the scar tissue, nice guitar.
