hygrometer test underway
johbren
Posted 2005-11-21 5:57 PM (#128744)
Subject: hygrometer test underway
salt, water, platic bag as described the exciting results will be posted tomorrow.
Posted 2005-11-21 8:43 PM (#128745 - in reply to #128744)
Subject: Re: hygrometer test underway
Great - they'll be no sleeping tonight... :rolleyes:
Posted 2005-11-22 7:33 AM (#128746 - in reply to #128744)
Post the results! Post the results! Post the results ....
johbren
Posted 2005-11-22 9:37 AM (#128747 - in reply to #128744)
The results are that the hygrometer went to 100% so its off at least 25%. Id like to say that its one of those type that you hang on the wall so its probably not right. I guess ill have to invest in one of those better ones like MF has.
Posted 2005-11-22 11:24 AM (#128748 - in reply to #128744)
Get one for each case, the humicase hygrometers work fine. You have to test those before you put them in, but the advantage is, unlike the mechanical ones you never have to recalibrate it (or so I'm told) but you'll have to buy batteries every year. Not really a big deal. For humidifiers, I like the Planet Waves in hole type. For outside the hole, they have a clay type deal in a plastic container that's pretty good.
Some people put in an apple, other use a sponge in a plastic bag.
I like the apple because your case will smell nice, and you'll have something to eat if you run out of food.
Alaskan Fly Guy
Posted 2005-11-22 11:46 AM (#128749 - in reply to #128744)
July 2004
So easy to make. Take a pill bottle or go to REI and pick up a few of those small nalgene containers (about 1" round X 1" or 2" tall). Drill several small holes in the top and cut a piece of "eva-foam" which is the green foam that florists use and put in the container. Soak in distilled water and put it in your case. I check mine each week or so. For about $10.00 you can make a dozen of these things.
Posted 2005-11-22 11:54 AM (#128750 - in reply to #128744)
"eva-foam"
. . also known as "Oasis".
Posted 2005-11-22 12:25 PM (#128751 - in reply to #128744)
35mm film container with three paper punches and a wet sponge!
I'll send you some if to use Paypal... ;)
