My '79 1115: yukkie discovery
bauerhillboy
Posted 2007-12-26 7:07 AM (#68672)
Subject: My '79 1115: yukkie discovery
I'm about to put an OpPro in this old 12 string. It's my main guitar and came from ebay with it's share of problems which have since been fixed. One of the troubles was a distorted top/turning bridge.
As I take a close look inside I see that there are 6 fan braces. The outer 2 are solid spruce, but the 4 braces in the center are made of 3/16" PLYWOOD! They're about 1/2" high. Can this be a good idea? From what I've heard over the years, these tops struggling to keep their shape seems to be a common problem. This looks like it was a bad design experiment. Any of you noticed this before?
John <>{
AussieJames
Posted 2007-12-26 7:24 AM (#68673 - in reply to #68672)
Subject: Re: My '79 1115: yukkie discovery
June 2007
Hi John,
Not having had much experience with Ovation acoustics I can't really comment on your guitar.
However coming from an engineering background I can definitely say that some plywoods are a lot stronger than solid timbers.
There are others on here with a lot more experience that may care to comment.
Cheers AJ
Posted 2007-12-26 7:52 AM (#68674 - in reply to #68672)
I would doubt it ever left the factory like that. Sounds like someone has tried to fix a
top problem with a half-assed DIY repair
bauerhillboy
Posted 2007-12-26 8:30 AM (#68675 - in reply to #68672)
I don't know, Temp. These little plywood braces seem very well integrated into the cross-braces and bridgeplate, and there are no glue marks from old work. I say these things a little tongue-in-cheek because, as is the case with Ovations, the bracework leaves a lot to be desired...strictly functional, rough wood, braces cut around the bridgeplate with plenty of space between the two instead of accurately cut and fit. But anyway, I'd be interested to hear from 1115 owners to find out what they see inside their guitars.
Posted 2007-12-26 12:41 PM (#68676 - in reply to #68672)
Never seen plywood for braces, & I've owned 3, so far. Understand the concept, but would argue with the practice.
Is it possible the top was replaced? How good is the binding job on the top, and does it appear "original"?
Posted 2007-12-26 1:23 PM (#68677 - in reply to #68672)
It sounds like you have one that had some careful repairs with questionable materials. If it works - use it!
Posted 2007-12-26 5:02 PM (#68678 - in reply to #68672)
.....what he said. "If it ain' broke....."
Posted 2007-12-26 6:14 PM (#68679 - in reply to #68672)
...You're not trying!
RG
