A shim for my Adamas
Bradley
Posted 2012-09-29 1:56 AM (#459736)
Subject: A shim for my Adamas
Where can I get a shim for my adamas? TIA.
Bradley
Posted 2012-09-29 2:06 AM (#459737 - in reply to #459736)
Subject: Re: A shim for my Adamas
Cut up any credit card.
Really!
Any plastic material like that. Something that is good and solid.
I say credit card, but library card, Safeway card... Whatever.
Just depending on the thickness of what you need.
bburg
Posted 2012-09-29 5:01 AM (#459741 - in reply to #459736)
August 2009
I'm with Arthur, if you need more thickness, cut up a circuit board, even more, lookout to get a bone saddle of a classical guitar and use it flat.
Bernie
Darkbar
Posted 2012-09-29 7:16 AM (#459743 - in reply to #459736)
January 2009
Good question. I KNEW about the credit card solution, hadn't heard about using a bone classical saddle. In a perfect world, I guess a sliver of bone or maybe a sliver of tusc would be the best shim material???? If not, what?
marenostrum
Posted 2012-09-29 8:42 AM (#459745 - in reply to #459736)
August 2007
Normally the less you put under a saddle the better. However It should be consistent material like bone or brass (or wood, why not....).
bburg
Posted 2012-09-29 8:56 AM (#459747 - in reply to #459736)
August 2009
I mean: Don't use SEVEN stripes of credit card material. If you have to use shims, try to use only one.
Bernie
MarkF786
Posted 2012-09-29 7:19 PM (#459775 - in reply to #459736)
April 2011
The obvious answer is to call the factory. When I contacted them about shims, I was prepared to buy some but they graciously sent me a bunch of them for free.
Edited by MarkF786 2012-09-29 7:20 PM
rick endres
Posted 2012-09-29 8:53 PM (#459776 - in reply to #459736)
August 2005
I have an envelope full of shims for a 1971 Balladeer that the factory sent (for free) along with a saddle...
Edited by rick endres 2012-09-29 8:54 PM
