Light Surface refinish - how?
Nasdtrader
Posted 2012-03-03 1:36 PM (#451354)
Subject: Light Surface refinish - how?
February 2007
I have a bunch of pic-marks all over my 2078lx (black top), and somehow remember a long time ago someone posting about using a product to take the "swirl marks" out of their top. Has anyone used a re-finishing product to remove pic marks?
Thanks for the help!
Posted 2012-03-03 2:08 PM (#451357 - in reply to #451354)
Subject: Re: Light Surface refinish - how?
I don't know if I'd recommend this on your guitar, but I'll tell you what I did on my $150 Ultra GS. It had heavy pick marks above the strings and into the pick guard. I wet sanded it with 2000 and 1500 grit to take most of it out. Then some polishing compound. Then some 3M or Maguire's swirl remover. All of this is available at an auto supply store or you might be able to order it from StewMac. The swirl remover takes a ton of elbow grease, so I used a soft cotton rotary buffer that attaches to a drill. That really polished it up nice. There's only a couple of the deep scratches left out of hundreds. I'm sure I went through most of the clearcoat, which is probably thinner on yours, so you might just try the swirl remover first and see if it takes them out. If not go up my process backwards.
Edited by Mark in Boise 2012-03-03 2:10 PM
Posted 2012-03-03 5:46 PM (#451371 - in reply to #451354)
I used the Micro Mesh soft sanding pads from StewMac on my Patriot. It worked quite well. If I were more aggressive maybe I could have done even more.
http://www.stewmac.com/shop/Tools/Sanding_Tools_and_Supplies/Micro-...
A little water helps when using these pads. The coarser pads cut pretty quickly. Use care. The finer pads take more time but will get a pretty good shine.
Jonmark Stone
Posted 2012-03-03 5:53 PM (#451372 - in reply to #451354)
From the auto department @W-Mart or auto store... Meguiar's Scratch X2.0. It does wonders on the catalyzed poly tops and necks.
Edited by Jonmark Stone 2012-03-03 5:59 PM
Nasdtrader
Posted 2012-03-03 7:30 PM (#451381 - in reply to #451354)
February 2007
Super! thanks for all the replies. Not sure yet what I'm going to go for, but i'll do before/after pics so hopefully we can have an idea of what can be done (or what not to do) if other people want to do the same.
Posted 2012-03-04 10:50 PM (#451441 - in reply to #451354)
Meguire's scratch X
javaman
Posted 2012-03-04 11:03 PM (#451442 - in reply to #451354)
January 2007
If you use an automotive product make sure it's a polishing compound, and not a rubbing compound. Go lightly with a piece of cheesecloth or cotton rag and do it a little at a time so you don't remove too much finish. But before you do anything, try using your fingernail to see if the scratches catch on your nail, if they don't, you should able to polish the scratches out nicely.
AdamasW597
Posted 2012-03-04 11:06 PM (#451444 - in reply to #451354)
November 2008
Meguiars Scratch X 2.0 worked great on a little black GC 057 I bought. It looks like a new car.
