action service
Phillym
Posted 2009-06-27 12:14 PM (#409573)
Subject: action service
June 2009
Does anyone know of a place that will adjust the action on my ovation. I live in scotch plains nj and called sam ashe but they want me to leave the guitar for a week.
BT717
Posted 2009-06-27 12:54 PM (#409574 - in reply to #409573)
Subject: Re: action service
October 2007
Have you tried taking a shim or 2 out from under the saddle/bridge?
Phillym
Posted 2009-06-27 1:41 PM (#409575 - in reply to #409573)
June 2009
NO, I read the owners manual and think I am pretty handy but never having done anything like it I was a litte nervous to try. When I fret the low e string on the first and last fret the neck seems dead straight but the action seems high from the 9th freet down.
Posted 2009-06-27 1:56 PM (#409576 - in reply to #409573)
Just do it yourself, you can't ruin anything by removing a shim. You can always put it back if the action is too low.
If the neck is dead straight you might need to back off the neck rod a little. Don't be scared of that either. Try a search in the archives and you'll find instructions on how to do it
Basic action adjustments and general set-up are well within the scope of the average guitar owner and are skills worth developing.
Posted 2009-06-27 2:00 PM (#409577 - in reply to #409573)
Go to the FAQ and read the 12th Q&A.
GaryB
Posted 2009-06-27 3:19 PM (#409578 - in reply to #409573)
August 2007
You can do it yourself as others have suggested; but if you decide to have the guitar serviced for this, or for any other reason, a week is not a long time to wait. Anyone worth their salt, service wise, will generally take much longer than that. The good techs are very busy people. Down here in Austin, a month to 2 is the norm, and longer if you're having a bigger job done, like a neck reset, or fret work.
Posted 2009-06-27 7:43 PM (#409579 - in reply to #409573)
On the other hand, it's less than 5 minutes to loosen the strings, pull the shim and tweek the neck and retune. That's assuming you don't have a string crank.
Posted 2009-06-27 10:00 PM (#409580 - in reply to #409573)
What Beal said +1...
