1612 Balladeer Questions????
John Quinn
Posted 2008-06-04 9:43 AM (#36504)
Subject: 1612 Balladeer Questions????
April 2007
I have acquired a 1612 Balladeer. It is in rough shape with 2 big cracks on top and battery holder has been moved and needs to be rewired, as well as the wiring to pickup. Seems one wire is not soldered. I am trying to date this. I can't find the serial number, may have been removed. The neck is not the 5 piece version, it is just solid mahogany, and the neck adjustment is from inside the soundhole. OHSC. Can I get an approximate year from these features? Any info will help.
Thank you,
John
johnquinn@cinram.com
jqballer1@yahoo.com
Posted 2008-06-04 10:06 AM (#36505 - in reply to #36504)
Subject: Re: 1612 Balladeer Questions????
They were made 1975-1984.
Posted 2008-06-04 10:13 AM (#36506 - in reply to #36504)
By the neck & lack of TR, I'd venture Early80's . .
John Quinn
Posted 2008-06-04 10:55 AM (#36507 - in reply to #36504)
April 2007
Thank you for your input. So in the early 80's they made cost effective moves on the neck, making it 1 piece and no headstock neck adjustment? Or was this better design?
Posted 2008-06-04 11:30 AM (#36508 - in reply to #36504)
It was the advent of the KamanBar (hence, the neck adjustment inside the bowl) instead of the traditional truss-rod.
I may be wrong, but I believe the necks are two pieces of the same wood that give the appearance of one-piece (again,I"think") . . .
Probably the best person to "date" this would be Moody, but he's busy replacing his Glenn Campbell poster with Bob Taylor photos & filling out the entry forms for Scientology . . .
John Quinn
Posted 2008-06-04 11:52 AM (#36509 - in reply to #36504)
April 2007
Great info. Does any one know where I can find a diagram for the pickup. Seems like there is a lead not soldered. The main white wire coming out of the bottom of the pickup is good, but then there is a post with some solder on bottm of pick up, but no wire. Would this be just a ground wire?
Fridave
Posted 2008-06-04 7:26 PM (#36510 - in reply to #36504)
February 2008
Not sure if this will help, it's from my owners manual for my '79 1612, hopefully you can magnify the print and find what you're looking for.
John Quinn
Posted 2008-06-05 9:09 AM (#36511 - in reply to #36504)
April 2007
Thank you very much. Every little bit of info helps!
