Adamas - What Would YOU Do ???
Posted 2003-02-10 7:38 AM (#212562)
Subject: Adamas - What Would YOU Do ???
I have a two-knobber Adamas. The electronics seem much noiser to me than more modern systems, the Preamp box is very heavy and changing the battery is a pain in the arse. I'm thinking of upgrading the electronics, but don't want to damage too much the overall look and collectability of the guitar. So what would YOU do? I thought of the following options.
1) Remove everything, glue the two wooden knobs on as decoration only, and install a nice Fishman or something similar.
2) Have the factory gut it, slice into the bowl and install something modern like Optima or OP-50.
3) Other suggestions ???
Thanks, Dave
Posted 2003-02-10 7:45 AM (#212563 - in reply to #212562)
Subject: Re: Adamas - What Would YOU Do ???
wait for the new models to come out and buy another guitar to use out for performance.
or you can wire the pickup to the output jack and use an outboard preamp.
I would not alter the guitar but understand your frustration. I too like the newer preamps but LOVE the acoustic sound of the older Adamas guitars.
Glueing the knobs would NOT be an option just keep the old guts in there and leave this as is non functioning
Posted 2003-02-10 7:54 AM (#212564 - in reply to #212562)
Here's a variation on Al's suggestion. Stick any old pots in the guitar to mount the controls on, this would be non-functioning to keep the original appearance. Buy a project box from Radio Shack and mount the existing pre & battery in there, or get a later pre-amp and do the same. Use this as an external pre & wire the pickup direct to the existing output jack. This way you can always convert back if necessary. I wouldn't get into an onboard preamp upgrade on a such a classic model. Ovation pre's crop up occasionaly on ebay, I have a few that cost me around $40 each.
Legend-LX-Fan
Posted 2003-02-10 12:40 PM (#212565 - in reply to #212562)
I find my two knob Adamas to be very quiet when plugged in. Has it always been kinda noisey to you? Please don't modify it! That would hurt...Paul Hebert
Posted 2003-02-10 2:08 PM (#212566 - in reply to #212562)
Guys,
Thanks for the suggestions. I like the idea of installing some old pots to mount the knobs and going direct from the pickup to the output jack and on to a pre-amp. But isn't there some issue with the distance between the pickup and preamp needing to be as short as possible?
musicamex
Posted 2003-02-10 2:22 PM (#212567 - in reply to #212562)
paul t, you are a wealth of imformation and ideas. i enjoy reading and learning from your posts.
Posted 2003-02-10 2:30 PM (#212568 - in reply to #212562)
Russ, glad to be of service.
Yes, because the output impedance is so high there's a chance that the cable, as it's unbalanced could pick up noise. If you use high-quality screened cable and keep the cable as short as is practical to reach a floor-box you should be OK. You could also consider mounting the box on your belt or guitar strap.
BruDeV
Posted 2003-02-10 9:06 PM (#212569 - in reply to #212562)
Another option is to use a wireless setup. Some of the newer ones have real small transmitters. Maybe you could attach it inside?
