The Ovation Fan Club | ||
Random quote: "Ovation Guitars really don't get the respect they deserve!" - Alex Pepiak |
Members Forums -> About my guitar... | Message format |
Kansas Boy![]() |
Joined: November 2012 Posts: 23 Location: Flint Hills of Kansas, USA | I recently ran across a NOS 1778T black beauty that I had to have. I purchased the guitar from a store in another state and the guitar arrived at my door Saturday before last. I really like the guitar and it plays well and the action is good, mostly... When playing, it is VERY easy for the high e string to 'slip off' the end of the fret. The problem seems most evident below the 5th fret. I've played guitar since 1984 so I don't believe it is my technique causing the problem. I have not experienced the problem on my 2778LX that I got from the same store last year or any other guitar for that matter. Nothing at the nut or saddle looks glaringly wrong to me and string spacing appears even between strings and across the fretboard. I'm at a loss why it is so easy for the high e string to fall off the end of the fret. Pull offs from 3 2 to open on the high e are really touchy on this 1778T. I can do them cleanly but I have to use extreme pressure on my fingers to keep the string in place while executing the pull offs. Sometimes while chording I can feel the string wanting to eek off the edge of the fretboard. The current set up makes that high e way too touchy for my liking. Any one have any ideas? I want to get back to loving my new Ovation!! Thanks, Kansas Boy Edited by Kansas Boy 2012-11-19 12:18 PM | ||
Mark in Boise![]() |
Joined: March 2005 Posts: 12759 Location: Boise, Idaho | Do you know what guage strings are on it? Maybe someone put on a really skinny one. I would think the fretboard radius would be the same as the 2778 and assume you compared the high e string location on both guitars to see if it's closer to the edge on the 1778. BTW, as a KSU alumn, I should have welcomed you before the Wildcats self destructed. | ||
Kansas Boy![]() |
Joined: November 2012 Posts: 23 Location: Flint Hills of Kansas, USA | Mark in Boise - 2012-11-19 12:34 PM Do you know what guage strings are on it? Maybe someone put on a really skinny one. I would think the fretboard radius would be the same as the 2778 and assume you compared the high e string location on both guitars to see if it's closer to the edge on the 1778. BTW, as a KSU alumn, I should have welcomed you before the Wildcats self destructed. Thanks for the reply Mark! I will soon know the string gauge as I will be changing them the first chance I get. I've been talking with the store and I didn't want to change their 'original set up' while they were still trouble shooting. I haven't had the time to go at this problem full bore as work has been taking up a lot of time since the guitar arrived. I did do a side by side comparison of the 1778T and the 2778LX. By 'eyeballing' the fretboards and string positions of the two they look fairly similar. The angle on the end of the frets is a bit different with steeper and shorter ends on the 2778 and a longer more gradual taper on the end of the frets of the 1778T. I'm hoping the solution is as simple as a string change...I'll get them changed out this evening. Yeah, I heard about K-State...it was hard NOT to hear about K-State around here! A lot of my buddies went to K-State (I didn't!) and they bleed purple but I don't follow the Wildcats very closely. Thanks for the welcome and thanks again for the reply. Kansas Boy | ||
FlySig![]() |
Joined: October 2005 Posts: 4065 Location: Utah | It sounds from your description that the position of the 1st string slot on the nut is normal, not too close to the edge of the fretboard. Other than string gauge I can't think of anything other than the shape of the end of the frets. | ||
Geostorm98![]() |
Joined: September 2011 Posts: 402 Location: New Hartford CT | Just for the heck of it try measuring the neck width using a caliper at the points where you're slipping off; compare with your other guitars. Also measure from high e to the neck's edge and compare again. | ||
MWoody![]() |
Joined: December 2003 Posts: 13996 Location: Upper Left USA | Aw heck, just take pictures! Welcome! | ||
Kansas Boy![]() |
Joined: November 2012 Posts: 23 Location: Flint Hills of Kansas, USA | Well, put new strings on last night and still have the issue. Thank you for the input FlySig. Geostorm98, I will do as you mentioned and see what I come up with. Thanks MWoody. I do have a ton of pics that I took at the request of the store to assist with their troubleshooting efforts. I did hear back from the store yesterday and their recommendation was to have another groove cut in the nut inside of the old one. Not sure I really like this response to the problem. Sure it would move the string further on to the fretboard but I would think string spacing between e and b would be compromised, wouldn't it? Thanks for all the input! I'm anxious to get my new 1778T up and playing! | ||
