Todays Project: 1114 Preamp Install
Posted 2007-03-31 9:37 PM (#107670)
Subject: Todays Project: 1114 Preamp Install
Got the Folklore off of Ebay today. It had nylon strings, a sunken belly and a "Tree of Life" set of finish cracks. It has seen some temperature extremes in a short time.
Decided to install a Fishman pickup and preamp sysstem also garnished from Ebay. Worked the neck, made adjustments, oiled, cleaned and played loud music, etc.
Jason_S
Posted 2007-03-31 9:44 PM (#107671 - in reply to #107670)
Subject: Re: Todays Project: 1114 Preamp Install
looks good mike,i installed a fet-3 tone/vol preamp and thinline pup in my 1114. compared to mine how does that one play/sound?? jason
Posted 2007-03-31 9:55 PM (#107672 - in reply to #107670)
Woodrow - you never cease to amaze and inspire me! How does it sound?
I am planning on doing a few more things to the CB - I installed the OpPro successfully but ended up absolutely butchering the bridge with a wayward dremel. I think I'm just going to end up refinishing it and putting a new bridge on it.
Posted 2007-04-01 12:56 AM (#107673 - in reply to #107670)
Sound is as big as your Folklore Jason. Good/Bad is that the sunken top allows for a higher saddle and more volume. Also, there is a 12-14 fret bump which limits the action setting.
Right now it is a strong player with decent action. The preamp has a tuner and 3 Eq levels. There is a Qtr and XLR output. The piezo is a Fishman coaxial thingy that is flexible which allowed me to fill up the slot.
This one is intended for a friend of mine - Steve - that has a budget and a Band.
Acoustic Reflections may be playing a Wedding in your home town! ;)
Crim - take a look at the bridge in another thread where they routed and filled with Walnut then cut a new slot.
Posted 2007-04-01 1:02 AM (#107674 - in reply to #107670)
Mike - looks like I am going to be taking a bridge off of Roundback's hands. The question that we both had was how to remove a bridge from a top without inflicting any damage.
Jason_S
Posted 2007-04-01 1:09 AM (#107675 - in reply to #107670)
i would try steam and heat. ive never tried to remove one off of a intact insturment....jason
Posted 2007-04-01 1:49 AM (#107676 - in reply to #107670)
Air-chisel! Didn't we talk about that before?
No, that was epaulets.
MWoody--"Tree of Life" set of finish cracks.-- And I'm sniveling about a little crack on mine.
"I was sad cuz I had no shoes, till I met a man with no feet!"
