Error encountered in: \\fs1-n02\stor2wc1dfw1\397573\426710\www.ovationfanclub.com\web\content\megabbs\templates\ovationfanclub\fragments\message.asp
Microsoft VBScript runtime error - Type mismatch
Ovation FanClub(tm)
difference between EA-68 and CV-68
tbran1996
Posted 2006-03-10 9:41 AM (#262833)
Subject: difference between EA-68 and CV-68
Posted 2006-03-10 10:30 AM (#262834 - in reply to #262833)
Subject: Re: difference between EA-68 and CV-68
It has been quite a while since I had to opportunity to play both but I remember being much more impressed by the feel and the sound of the USA viper.
Posted 2006-03-10 12:07 PM (#262835 - in reply to #262833)
There are a couple of things that come to mind regarding the construction of the two guitars (I've never played them back to back). First, everything that I've ever read says that the EA-68 uses better materials in the construction. I've heard of intonation problems with the CV-68. Also, the EA-68 uses a "thru the body" string attachment like a Fender Strat. The CV-68 uses the standard Ovation style pinless bridge. I would imagine that "thru the body" system would make better use of the chambered body and result in better body vibration.
BruDeV
Posted 2006-03-10 6:47 PM (#262836 - in reply to #262833)
CV-68 uses a plywood top the EA-68 doesn't. The EA-68 uses a different pickup as well.
Posted 2006-03-10 7:05 PM (#262837 - in reply to #262833)
Add one: EA68 has a 5 piece neck, Korean one has celebrity style 2 piece. Ebony vs. Rosewood fretboards. Like moody said, different bridges with different designs (I like the looks of the USA ... not your average Ovation bridge). Top is nice grade solid spruce vs. Lam on the Korean.
Posted 2006-03-11 5:22 AM (#262838 - in reply to #262833)
Do they weigh the same ???
Posted 2006-03-11 8:22 AM (#262839 - in reply to #262833)
and...
The CV-68 has a "CV" in front of the 68, two consonants, where as The EA-68 has a "EA" in front of the 68, two vowels. I kid you not.
