Carbon Fiber Allergie???
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | I said that to my daughters every night until a couple years ago. I should to call them on their cell phones and remind them. | ||
| tdeej |
Joined: November 2004 Posts: 286 Location: North Idaho | Could the little creatures have traveled in the case lining? | ||
| schroeder |
Joined: November 2004 Posts: 4413 | I think I'd ask for a second opinion. | ||
| JeffreyD |
Joined: September 2004 Posts: 777 Location: East Wenatchee, WA | Originally posted by tdeej: Wow....so we travel full circle and it really is an Adamas Allergy....bugs in the case the Adamas came in. How poetic...Could the little creatures have traveled in the case lining? | ||
| noah |
Joined: December 2004 Posts: 1673 Location: SoCal | Jeff, Have you found any physical evidence of the creatures? If the skin problem is localized to bare skin on the inside of your right arm where it crosses over the guitar and only occurs after playing the Adamas... how could it be bites? Do you store the Adamas in the new TKL case? The new synthetic fuzzy interior sheds a little. Loose inert fibers can still cause contact dermatitis. The rough bowl back could be transferring loose fibers to your shirt. The inside of your forearm could be picking up the fibers directly from the guitar or off your shirt later on. I'd vacuum the interior of the case very well, blow out the inside of the bowl, vacuum and wipe down the exterior of the guitar, put on a clean shirt, and play your Adamas... good luck and call me in the morning. | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | The binding edge on the lower bout of the U681T irritated the underside of my upper arm when I first got it. You can "chamfer" the binding edge with the spine of a kitchen knife. Go lightly. | ||
| Weaser P |
Joined: October 2005 Posts: 5333 Location: Bluffton, SC | Bed bug epidenic? | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Some great quotes in that - "We feel like we're starting from scratch". :rolleyes: | ||
| luthier444 |
Joined: March 2002 Posts: 255 | I was just curious what guitar polish you use on the guitar??? Plus the smell tends to be the case not the guitar... I had a Hamer Californian`s Finish bubble up because of the Case adhesive not being fully dry... Open the case and let it air out... Oh By the way i still dont think that Sambora Doubleneck is 10-15 years old??? When was Slippery when wet?? | ||
| TommyK |
Joined: January 2006 Posts: 208 Location: Illinois | CARDINALFLYER, Here's my take. If this is a brand spanking new guitar then the solvents that make the plastic liquid so that it will flow into the mold may be causing some irritation. As molded plastic ages it 'outgasses' the solvents. This what gives a car that 'new car' smell. You are smelling the outgassing of the plastics and vinyls that make up the inside of the car. Eventually that 'new car' smell goes away as the solvents dissipate. Unfortunately, some plastics eventually become brittle. Some plastics, however, retain their integrity long after that 'new car' smell goes away. The ovation guitars I've seen appear to have a cross-linked polyethylene bowl. I could be wrong. If it is xlpe, then I'd say it will last a long long time. I used to buy fuel tanks made out of this stuff and diesel fuel doesn't make a dent in it... it makes it swell a bit, but nothing to be alarmed about. Some people have sensitive skin and this little bit of vaporized solvent irritates them. My suggestion to you is to wear a long sleeved shirt or drape a wash cloth under your arm when playing. You might even cut the sleeve off an old long sleeved shirt to cover your arm when playing too. Eventually the outgassing will subside and not be a bother to you any more. Leaving it out of the case for a few months will accelerate the outgassing. Just make sure it's in a safe place, preferably hanging on the wall. While sunshine can accelerate the outgassing, I wouldn't recommend it with a guitar. Good luck! | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Jusk make sure you have a guitar made from Brazilian polyethylene. The Brazilian stuff doesn't pass as much gas. | ||
| Jump to page : 1 2 3 Now viewing page 3 [25 messages per page] |
