"TOOL" DEFINITIONS WOT
| Abendicum |
Joined: June 2004 Posts: 271 Location: Ft. Lauderdale, Florida | I got a laugh from reading some of these...From a Luthier site I peruse... I think the "wire wheel" is my (tried and true) favorite... Ab Found this on the web. Applicable to mechanics, but has applications in the wood shop... a.. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying. b.. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." c.. ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their holes until you die of old age d.. PLIERS: Used to round off bolt heads. e.. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. f.. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. g.. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of. h.. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. i.. HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender. j.. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack. k.. TWEEZERS: A tool for removing wood splinters. l.. PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack. m.. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting doggy-doo off your boot. n.. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit. o.. TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup. p.. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect. q.. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle. r.. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought. s.. AVIATION METAL SNIPS: See hacksaw. t.. TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under motorcycles at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. u.. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads. v.. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 40 years ago by someone in Sindelfingen, and rounds them off. w.. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. x.. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short. y.. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit. z.. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets -------------------------------------------------------------------------------- | ||
| TRboy |
Joined: February 2003 Posts: 2178 Location: the BIG Metropolis of TR | I agree with you about the "wire wheel" with the "trouble light" coming in 2nd!(they don't call them "trouble" for nuttin') I spend a good portion of my "free" time (my wife says "to much") piddling in my shop on various (mostly unfinished) projects and these descriptions are VERY funny and OH-SO-TRUE!! Ab, could you post a link to the luthier's site? | ||
| Capo Guy |
Joined: December 2004 Posts: 4394 Location: East Tennessee | If I laugh any louder my wife will wonder what I'm looking at. Thanks it's the best description of the tools I have in my garage. :D :D :D P.S. We really need a laugh graemlin for posts like this. I know irt has absolutly nothing to do with guitars, but it lifts the spirit almost as much as playing one. :) | ||
| GrilledCheese |
Joined: May 2005 Posts: 327 Location: Evansville,IN | Most of that has happened to me, at one time or another, mostly with cars, VW air cooleds in particular, lots of rusty bolts on them, and lots of skinned knuckles. :D | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | I have decided that screwdrivers have the ability to morph from blade type to phillips type at will. They somehow know what I'm looking and quickly change to the other kind. | ||
| WeaserP |
Joined: March 2005 Posts: 417 Location: Cicero, NY | That's whay I stopped caring - I'll drink any of 'em! :D | ||
