Input Jack Noise
Tommy M.
Posted 2005-10-23 10:40 AM (#132399)
Subject: Input Jack Noise
January 2004
Something in the input jack of my CL1619 is loose, because whenever I move, I get that cracking noise from my amp. My jack is ok. It happens from the mono input, which is the only one I use. I'm getting ready to take the strings off and reach down in there, but then what? Anyone ever have to correct this problem?
Posted 2005-10-23 10:48 AM (#132400 - in reply to #132399)
Subject: Re: Input Jack Noise
Have you tried another cable?
Tommy M.
Posted 2005-10-23 10:51 AM (#132401 - in reply to #132399)
January 2004
Yes, I know its not the jack cable, as it happens with all my cables. The same cables work fine on my other guitars.
Posted 2005-10-23 10:59 AM (#132402 - in reply to #132399)
Jack's probably got a bad connection. Same thing happened with my 1537. Take it to a competent tech. It'll cost about $30 to replace.
Posted 2005-10-23 11:01 AM (#132403 - in reply to #132399)
sounds like intermitant ground interuption. Could just be a matter of wiggling the leads from electronics to see if you can induce the same noise.
Make sure the jack shields are tight at the preamp.
Also change the battery.
Tommy M.
Posted 2005-10-23 2:28 PM (#132404 - in reply to #132399)
January 2004
Well I took the strings off and got my arm inside and felt for anything loose. Nothing. I got some electronic contact cleaner and sprayed the jack inserts clean, and bingo, no more cracking noise. 2 things to becareful about.
Do not get this contact cleaner on the guitar finish. I covered the top with paper. Also, the Ovation rossete comes loose, when sticking my big arm inside the bowl. I had to glue it back down.
