convert left/h 12 string Ovation to right/h?
J-a-y-S
Posted 2013-03-26 9:55 PM (#468904)
Subject: convert left/h 12 string Ovation to right/h?
March 2013
Hi,
I was just wondering how difficult it would be to convert a left /h to a right/h.
The nut would have to be changed - that wouldn't be hard.
The bridge, modified or changed?
Pickguard? perhaps just add the rh one.
I'd like to know of your experience or opinions.
Thanks so much
Steve
J-a-y-S
Posted 2013-03-26 9:59 PM (#468905 - in reply to #468904)
Subject: RE: convert left/h 12 string Ovation to right/h?
March 2013
no pickguard :P
Posted 2013-03-27 10:28 AM (#468914 - in reply to #468904)
Subject: Re: convert left/h 12 string Ovation to right/h?
It depends on the bridge. What model are you talking about, and does it have an original Ovation pickup? If so, it's pretty easy. Might need a fret job too if the frets have wear to them.
J-a-y-S
Posted 2013-03-29 9:38 AM (#468961 - in reply to #468904)
March 2013
It's a 1115-1 12 string, doesn't have a pickup.
Would it be possible to add a pickup too, I have one from a damaged ovation.
Thanks for your time.
Posted 2013-03-29 11:46 AM (#468965 - in reply to #468904)
Jay, because of the angle on the acoustic only bridge, this will be a hard one to switch over. The intonation would most likely be way off. Also, the Pacemaker has "Fan" Bracing I believe which is ALMOST symmetrical, but not quite:
This bracing has a slight variable as you can see (not a mirror image). It would be upside down if you flipped the strings and could produce unfavorable tonal qualities
Edited by Damon67 2013-03-29 11:47 AM
J-a-y-S
Posted 2013-03-30 4:27 AM (#469004 - in reply to #468904)
March 2013
Thanks for your diagram and time Damon,
Asymmetrical bracing. Well, doesn't that just tear it...
Cheers
"All knowledge is good, all ignorance is bad".
