Check the Ferrule Nut on the tuners FIRST!
Posted 2012-09-24 6:18 PM (#459516)
Subject: Check the Ferrule Nut on the tuners FIRST!
Just thought that I should Share That.
I just got a New-to-Me guitar and I was cleaning-it-up and all...
Changed the Strings, Oiled the Fingerboard cuz sharp Fret-ends were sticking-out..
Adjusted the Tremolo-springs (non-O)... And was ready to play.
But there was this annoying buzz on the open "G" string...
So I checked the frets and nut height, adjusted the truss-rod.. Still Buzzed!
Then I discovered that I could get the same buzz by playing a "G" on the D string...
and the A string... Same buzz not as loud!
So after checking for cracks, neck-bolts, back plates, truss-rod rattle, spring rattle and everything else that I could think of...
I did what I should have done First!
I tightened the the Ferrule-nut thingies on the Tuners...
Hence the Title of this Thread.
kitmann
Posted 2012-09-24 7:35 PM (#459518 - in reply to #459516)
Subject: Re: Check the Ferrule Nut on the tuners FIRST!
April 2010
Is the Ferrule nut thingies the screw on the end of the tuner, which I had to tighten on my Patriot or the screws that hold the tuner to the guitar. Reason I ask is I have never heard that term before, need to expand my vocabulary.
Posted 2012-09-24 8:29 PM (#459519 - in reply to #459516)
Threaded Bushings?
noah
Posted 2012-09-24 8:35 PM (#459520 - in reply to #459516)
Retaining nut?
Tuner bushing/ferrule... is usually a press fit.
Edited by noah 2012-09-24 8:42 PM
Posted 2012-09-24 8:52 PM (#459521 - in reply to #459516)
These thingies that hold the tuner in...
I imagine the washer is what made the buzzing sound...
Vibrating harmonically with a "G" note.
kitmann
Posted 2012-09-24 9:00 PM (#459522 - in reply to #459516)
April 2010
Now I understand, thank you guys
