custom legend
auto97
Posted 2009-04-10 10:00 AM (#419582)
Subject: custom legend
March 2007
Hi,
As a proud owner of lefthanded 1719. I ask if someone of You could give me advise. The two highest strings E and B have started sound little unbright. It is still in same action that was put in the shop I ordered it and 1719 feels great to play. The string set (EXP 16) is new. Some advise to tell to my luthier who likes more my Martins.
Happy Easter from Finland!
Ilkka
Posted 2009-04-10 10:17 AM (#419583 - in reply to #419582)
Subject: Re: custom legend
Welcome Ilkka! A healthy bunch of my ancestors are from Finland.
Advice... Take off the EXP's and put on EJ16's!
Others may have better advice. :eek:
GaryB
Posted 2009-04-10 10:37 AM (#419584 - in reply to #419582)
August 2007
OMA speaks wisely. John Pearse Phosphor bronze lights are good also, with a tad more tension than EJ16's.
Posted 2009-04-10 10:58 AM (#419585 - in reply to #419582)
Illka, welcome!
It could be the strings in the new set aren't as bright as you expected. The first thing I would do is try a different brand of string.
It is possible that the saddle is developing a groove. That does happen on new Ovations and is normal. Sometimes when the groove is forming, a little plastic bump forms on the front and back face of the saddle. That bump might be touching the string.
I usually have to use a small file or sandpaper to make the front and back of the saddle flat again.
auto97
Posted 2009-04-10 11:02 AM (#419586 - in reply to #419582)
March 2007
Thanks Gary and OMA(nationfellow). I was just wondering if it has something to do with adjustments because those EXP:s have done their job so well until recent times. Could it be tension in the top or...?
bvince
Posted 2009-04-10 11:16 AM (#419587 - in reply to #419582)
September 2005
I had a similar issue once. It ended up that as I had frequently wiped the guitar down with a cloth, some lint had built up under the strings at the nut. A good cleaning and very slight filing fixed the problem.
