op30 preamp not working?
sadtrout
Posted 2009-07-05 11:25 AM (#408452)
Subject: op30 preamp not working?
July 2009
I've just bought my first ovation but the preamp doesn't seem to work.I've read that there should be an output as soon as I plug in my lead but this doesn't happen. The only output I get is when I turn on the tuner, which only lasts for 60 seconds (not much good if you're playing live!).
Any ideas?
dweezil
Posted 2009-07-05 11:28 AM (#408453 - in reply to #408452)
Subject: Re: op30 preamp not working?
Welcome.
Have you tried swapping the battery?
Also what Ovation is it?
sadtrout
Posted 2009-07-05 11:43 AM (#408454 - in reply to #408452)
July 2009
Thanks.
I have just changed the battery and it doesn't seem to have made any difference.
It is a CU 147 Pinnacle.
dweezil
Posted 2009-07-07 2:41 PM (#408455 - in reply to #408452)
If you bought it new take it back to the shop.
If you bought it 2nd hand contact the seller.
Or take it to your local friendly guitar luthier...
tpa
Posted 2009-07-07 5:46 PM (#408456 - in reply to #408452)
I don't know if this is relevant to Ovations or to you but I heard that some guitars have problems when using a stereo jack ... but in Ovations the signal goes from the preamp to the receptacle using a wire and if that wire is loose or something signal will disappear the way you describe.
sard
Posted 2009-07-08 10:49 AM (#408457 - in reply to #408452)
June 2008
sad trout
When I received my first ovation, my preamp did not seem to work either, but I soon realized that the preamp was not fully engaged. A good firm press and it clicks back into place. Also the tuner stays on long enough to easly tune all the strings...hope this helps
