bracing wood on '74 1117
1617
Posted 2010-03-07 2:03 AM (#377731)
Subject: bracing wood on '74 1117
February 2009
I recently purchased a 1974 1117 and from what I can see, without sending a camera inside, is that the bracing has been stained black. The block where the neck is attached is black as well. Is this normal? Also the outside bowl is black textured with a glued on rubber anti-skid patch where as my 1617 bowl is brown with a painted on anti-skid texture.
Gallerinski
Posted 2010-03-07 7:38 AM (#377732 - in reply to #377731)
Subject: Re: bracing wood on '74 1117
Painting of the neck block black was common. I don't know about the braces.
Posted 2010-03-07 8:19 AM (#377733 - in reply to #377731)
Didn't they use that acoustically reflective paint?
Gallerinski
Posted 2010-03-07 9:06 AM (#377734 - in reply to #377731)
That came much later, after they did away with the wooden neck blocks. This guitar pre-dates that.
Posted 2010-03-07 9:35 AM (#377735 - in reply to #377731)
Fiberglass bowl...
cholloway
Posted 2010-03-07 12:31 PM (#377736 - in reply to #377731)
Shhhhhh.
Due to National Security we aren't allowed to mention the tests of the reflective paint that was eventually used on stealth aircraft.
