Ovation 1778 T Neck question
jonathan
Posted 2005-01-02 11:09 AM (#167592)
Subject: Ovation 1778 T Neck question
I have a new Ovation 1778 T, and I need to do some minor neck adjustments.
There seems to be two places where the neck adjustment might be. There is a cover on the headstock and there is also a hex nut adjustment inside the guitar (at the heel of the neck).
Is this a double truss rod? Which adjustment point do I use? (headstock or heel?)
ebee
Posted 2005-01-02 12:36 PM (#167593 - in reply to #167592)
Subject: Re: Ovation 1778 T Neck question
Just open up the truss rod cover on the headstock and adjust away!
I too have a 1778T and love it! I use a 3/16 size hex thingy. I think it would be the same for you too.
jonathan
Posted 2005-01-02 12:42 PM (#167594 - in reply to #167592)
So what does the adjustment at the heel do?
Thanks for the reply!
cms-man
Posted 2005-01-02 3:20 PM (#167595 - in reply to #167592)
October 2002
That is where the neck is bolted to the body.
jonathan
Posted 2005-01-03 5:14 AM (#167596 - in reply to #167592)
Ahhh!
Good thing I joined this board and asked that question.
I've seen Ovation guitars that have adjustments inside the bowl (hence the rear access) so I wasn't sure if this was one of those double-truss-rods or whatever.
Phew... good thing I asked.
:eek:
Posted 2005-01-03 7:25 AM (#167597 - in reply to #167592)
you would have had a fun time with the neck coming off and the strings at tension.....
