Jump to page : 123
1687 wood top proto
Posted 2008-03-17 3:22 AM (#305980 - in reply to #305930)
Subject: Re: 1687 wood top proto
Didn't a couple have the inlaids designed after Bill's wife's earrings?
Are there production serial numbers assigned to these?
Koenig Kurt
Posted 2008-03-17 7:16 AM (#305981 - in reply to #305930)
This is what the Collector's 2009 should look like.
I think the broccoli head and carved bridge is corresponding much better to the wood top than to a composite top.
Beautiful guitars!
Kurt
Posted 2008-03-17 9:00 AM (#305982 - in reply to #305930)
only the first two had the necklace inlays and Glen has one and I have the other.
There were very few of these made that cas has. I have one that was an experiment to see if we could use straight polyester finish which was very hard and would cold crack easily. We put a layer of real fine glass cloth, soaked it in the finish and put it on the top. The whole thing was then put against a flat plate and a the air sucked out and allowed to cure. Result is a nice flat shiney finish that is reinforced. In the end we didn't use this approach, too hard to do it. I found this guitar several years ago and it still sounds great. Has a finish crack though....
Posted 2008-03-17 9:49 AM (#305983 - in reply to #305930)
my guitar is a deadnaught size.
I also have a center sound hole that is dreadnaught sized.
they are boomers!
cas
Posted 2008-03-17 1:46 PM (#305984 - in reply to #305930)
March 2008
Soon i might have it played on stage by the lead singer of the deftones. So i will get a pic to put on here.
brainslag
Posted 2008-03-20 10:00 AM (#305985 - in reply to #305930)
Make sure he doesn't do a stage show with it and smash it into the drum kit.
Jump to page : 1 2 3
