Preamps,XRL,Phantom Power....a little 'clarity , if I can ...
titti
Posted 2013-12-25 11:16 AM (#480820)
Subject: Preamps,XRL,Phantom Power....a little 'clarity , if I can ...
January 2011
then ...., preamps of the series "OP" , those blacks with 8 pins : only the OP PRO supports Phantom Power. The VIP-5 and OP-PRO-STUDIO NOT SUPPORT the Phantom Power. Exception: if you have a OP PRO STUDIO ,you can put in place a OP PRO in the same can , and it ( the Op-Pro) will work in Phantom Power . then ... ah yes, XRL . If you want to use cable XRL, you need a "Ovation 9658 cable", or the cable "lo z grounded XLR cable" (for sale on Ebay) : I think are balanced cable polarity different from the normal XLR cables . OK , but if you want to use a normal XLR cables, you need to add at the output 1/4 jack a dummy-plug . At last, now I use a high-quality XRL cable :the volume,the sound .... In short, everything is much better than outpout jack ..... ufff, I hope I was clear ....
Edited by titti 2013-12-25 11:19 AM
kentrookie
Posted 2013-12-25 1:27 PM (#480822 - in reply to #480820)
Subject: Re: Preamps,XRL,Phantom Power....a little 'clarity , if I can ...
December 2008
Ok…. so thanks to the power of THE google I think I got it.
http://www.procosound.com/download/whitepapers/Understanding%20Micr...
Not sure after growing up listening to Vanilla Fudge and Quicksilver Messenger Service at the Paramount I can hear the difference (but willing to tr )
titti
Posted 2013-12-25 9:35 PM (#480827 - in reply to #480822)
January 2011
kentrookie - 2013-12-25 8:27 PM
...the page does not open .What's this?
kentrookie
Posted 2013-12-25 10:06 PM (#480828 - in reply to #480820)
Subject: RE: Preamps,XRL,Phantom Power....a little 'clarity , if I can ...
December 2008
Unsure why link doesn't link.....here are the words
What are the differences between high- and low-impedance microphones?
To answer this requires a little historical background. High-impedance microphones are capable of producing higher output voltages than low-impedance types. Until recently, "consumer" audio gear (small P.A. systems, home and semi-pro recording equipment, etc.) was always designed for high-Z mics because their relatively high output level required less amplification or gain. The lower output of low-Z mics required the equipment manufacturer to use input transformers in front of the mic preamplifiers to step up the strength of the signal, which substantially increased the cost of the circuitry. Hence, low-Z mics were rar outside of professional recording and broadcast studios. In these "big-budget" facilities, low impedance lines offered several big advantages. A high-Z mic's high source impedance (approximately 10,000 ohms) combines with the capactive shunt reactance of the mic cable to form a low-pass filter which progressively cuts high frequencies. The severity of the loss is determined primarily by the length and construction of the cable. (See "Understanding the Instrument Cable.") The low source impedance (less than 200 ohms) of low-Z microphones proportionally reduces the high-frequency loss. Equally important, the high load impedances demanded by high-Z lines are much more susceptible to various forms of interference than low-Z lines, especially high-frequency noise and radio. Both of these high-Z liabilities made cable runs longer than 15-20 feet a problem.
Isn't the use of balanced lines the biggest advantage of low-impedance microphones? What is a balanced line? Balanced lines are wonderful, but they are sometimes given credit for benefits that they are not actually responsible for. Balanced, unbalanced, low-impedance and high-impedance are all individual properties. Many people erroneously refer to anything with a 3-pin XLR-type connector as "low impedance" and assume it to be "balanced." Others call any line connecting two pieces of equipment with 1/4" phone jacks "high-Z." In reality, a lot of equipment has unbalanced inputs and outputs that are carried on XLR connectors, and there are even more low-Z lines on phone jacks. Medical instrumentation uses a lot of high-impedance balanced lines for sensors, and most line-level unbalanced outputs are very low-impedance. Electrical systems need a reference point for their voltages. Generally referred to as common or ground, although it may not be actually connected with the earth, this reference remains at "zero volts" while the "hot" signal voltage "swings" positive (above) and negative (below) it. This is referred to as an unbalanced configuration. Physically, the common may be a wire, a trace on a printed-circuit board, a metal chassisÑvirtually anything that conducts electricity. Ideally it is a perfect conductorÑthat is, it must have no resistance or impedance. In a cable connecting two pieces of equipment, the shield is used as signal common. As the complexity and size of the system is increased, the imperfect conductivity of the common (ground) conductor inevitably causes problems. Since it is made of a real material, it must have some resistance, which must (Ohm's Law says) cause voltage drop when current flows through it, which means it cannot be at a perfect "zero volts" at both ends. The larger the system and the greater the distances between the source and load, the less effective this unbalanced configuration becomes. The voltages of a balanced line are not referenced to the ground or common. Instead, the signal is carried on a pair of conductors with the signal applied to this pair differentially. The signals are electrical "mirror images" of each otherÑtheir levels are the same, but their polarities are opposite. In other words, as the applied signal "swings," one conductor will be negative with respect to the common, the other will be positive. These polarities alternate with the frequency of the signal, and the total signal level is the difference between the two individual voltages. For example, if one conductor is at +5 volts, the other will be at -5 volts, and the signal level is +5 volts minus -5 volts or 10 volts. If, for same reason, the two conductors were both at +5 volts simultaneously, the level would be +5 volts minus +5 volts, which is zero volts. Very tricky! Because of this differential signal transmission, two very valuable things happen when using balanced lines. First of all, each piece of equipment can have its circuitry referenced to its own common, because the interconnection of the equipment does not require that the commons are connected in order to move the signal around. This eliminates the major cause of a lot of noisy audio gremlins, ground loops. Secondly, because the signal is differentially transmitted and received, any common-mode interference signal superimposed on the signal in the line will be carried by both sides at identical level and polarity. In other words, if the line has +5 volts of external noise induced, both conductors will have +5 volts of noise on them. This equals a total interference level of +5 volts minus +5 volts or zero volts. The interference cancels itself. This is called common-mode rejection. There are several ways to balance lines. (Actually, the term "balanced" is very often used incorrectly to refer to lines that are actually floating. Properly speaking, a balanced line is one which has equal impedance from each side to ground. An unbalanced signal may be derived from it by using one side of the pair as "hot" and ground as common. A floating line has no reference to ground, and must have on side of the line tied to common to "unfloat" it.) The input transformers once required by low-Z mic preamps also provided a floating input as long as neither side of the transformer's primary winding was tied to common. This is where the "low-impedance-is-balanced" misconception began. The use of balanced lines was actually just a by-product of the requirement for a transformer to step up the low signal level. Using modern low-noise integrated-circuit design, a low-Z mic preamp can be clean, quiet, balanced and a lot cheaper to build without a transformer.
titti
Posted 2013-12-26 4:49 AM (#480832 - in reply to #480828)
January 2011
uhm ...., I did not understand very . However I have always heard that the XLR cables are useful to great lengths (10,15 mt.) . And for acoustic guitar amplification . I bought from my technical of the Ovation assistance a XRL cable , a high-quality cable (130 euro's ) , The difference from a normal jack cable you feel all right ....it's only a suggestion ? perhaps....can be....
Edited by titti 2013-12-26 4:51 AM
