AFTERMARKET PICKUP FOR 70'S PACEMAKER ACOUSTIC 12-STRING?
rick endres
Posted 2011-08-17 10:30 AM (#349448)
Subject: AFTERMARKET PICKUP FOR 70'S PACEMAKER ACOUSTIC 12-STRING?
August 2005
I want to put a pickup in a '70's Pacemaker 12 string. I want to alter the guitar as little as possible; no knobs or dials or sliders or control panels. A luthier recommended Fishman's acoustic matrix. I've always been happy with Fishman; I was just curious to see what you guys thought.
Posted 2011-08-17 10:37 AM (#349449 - in reply to #349448)
Subject: Re: AFTERMARKET PICKUP FOR 70'S PACEMAKER ACOUSTIC 12-STRING?
Lots of good possibilities out there. On the cheap I get the Artec Piezos on Ebay and they can plug into most any Preamp.
You might want to consider adding the iDea like this one:
Preamp added to a Pacemaker
Posted 2011-08-17 10:54 AM (#349450 - in reply to #349448)
Technically, you can run the piezo, undersaddle pickup to a 1/4" output jack, then to your amp. You might make your life a bit easier by buying a 3/32" female jack, so you can just solder it into the circuit, instead of whacking off the male jack on the pickup lead.
scott lamperd
Posted 2011-08-17 11:18 AM (#349451 - in reply to #349448)
Check out L R Baggs pickups LB6 series. These work really well with ovation acoustic conversion.
scott lamperd b c (before computers)
rick endres
Posted 2011-08-17 11:43 AM (#349452 - in reply to #349448)
August 2005
James Taylor likes L R Baggs; that's a high recommendation.
These are all good suggestions. I don't mind a jack in the bowl (there's a hole for one; in a weak moment I once hard wired a Dean Markley ProMag in it! :D ).
