Stiff action on Celebrty cs-257
jbavar
Posted 2002-04-27 2:34 AM (#222526)
Subject: Stiff action on Celebrty cs-257
April 2002
I have a new Ovation Celeberty CS-257 and the action seems a lot stiffer than my old Matrix. Bar chords are much tougher on the Celeberty. I know its not a good idea to shave the saddle but do you have any suggestions for easing the action.
thanks.
JB
Harlan
Posted 2002-04-27 4:24 AM (#222527 - in reply to #222526)
Subject: Re: Stiff action on Celebrty cs-257
April 2002
Check for shims underneath the bridge that are removable to adjust string height. If there are no shims to remove, try adjusting the neck. {if you've never adjusted a neck before, better take it back to the store you bought it from for adjusting and check out how its done} If none of these things work, try exchanging it for a better one or contact the factory with your warrenty. Hope this helps,,,,,,,,,Harlan
musicamex
Posted 2002-04-27 5:01 AM (#222528 - in reply to #222526)
harlan, hey sourdough. i see from your profile you run a recording studio. soldatna has changed a little since '68 i guess. pull up a chair and dry out your muclucs amigo, this is a good fire to hang around.
Harlan
Posted 2002-04-27 9:54 AM (#222529 - in reply to #222526)
April 2002
Thanks for the welcome Russ! I was looking for a serial no.-year chart to identify what year my ovation was and found a bunch of ovation nuts like me! Yea, its changed quite a bit since 68 but its still a small town all in all. I've been here since 71. Thanks again and there's an extra hook for wet mucklucs's if you ever want to come back and check it out. You know you can leave Alaska but somehow Alaska never leaves you. Harlan
musicamex
Posted 2002-04-27 5:14 PM (#222530 - in reply to #222526)
harlan, you're right. alaska is something i will never forget. maybe i will head back up for a summer someday. i'm livin in mexico now--traded my mucklucs for tevas. come south sometime when it's 40 below-- good for the bones. eat some king crab for me amigo.
