1979 Viper Bridge Setup
O'mike
Posted 2003-12-27 7:05 PM (#198921)
Subject: 1979 Viper Bridge Setup
What is considered to be the procedure for setting up the thru the back bridge adjustment and how it relates to the two hight adjustments on the top?
Posted 2003-12-27 8:25 PM (#198922 - in reply to #198921)
Subject: Re: 1979 Viper Bridge Setup
Hi Mike,
I'm not an expert in this area, but the only thing I did on mine was use the two top adjustment screws to set the action wher I liked it wrt the neck angle. There's probably a more scientific approach, but through trial and error I was able to dial it in just where I wanted it. You need to make sure the neck is straight as well. The last thing I did after getting the action set was to adjust the pickup heights.
BruDeV
Posted 2003-12-28 12:38 AM (#198923 - in reply to #198921)
I use the two top screws to set the action, then use the rear screw/nut to get the bottom plate of the bridge parallel to the strings. If you get it too far away from parallel it will change the radius formed by the bridge saddles.
Before threading the string through the bridge, put a bend in the string about one inch from the end. It will feed in easier. (That's the end opposite of the ball).
O'mike
Posted 2003-12-28 6:07 PM (#198924 - in reply to #198921)
O'mike
Posted 2003-12-28 6:08 PM (#198925 - in reply to #198921)
[QB][/QB]
Thanks guys
