OFC GUITAR - LASER VIBROMETER PLOTS
| stonebobbo |
Joined: August 2002 Posts: 8307 Location: Tennessee | Wow! EA, was this run at the recent slothead reunion? I wonder how much of this is attributable to lots of play. What was the original reading (did they do that on the slotheads?) Might answer the question of whether they "open-up" or not. | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | I think No. 43's plots were made back in the days when horsepower was gross rated at the flywheel. | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | That is some range, if I have any clue what this means. | ||
| elginacres |
Joined: July 2005 Posts: 1609 Location: Colorado | Sheesh - am I that old perfesor? This plot was made at the slothead reunion a couple years ago...I'll see what else I can dig up out the archives - a.k.a stack of papers on the dresser in the basement. Mark | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | Webpage is updated. Now includes a section for the plots of the original slotheads. http://www.roundbackguitarforum.com/vibrometer.htm So far Mark's #43 is the only original one. If anyone else has plots of their originals and wants to share them, please do. I'd love to have a plot of # 42 but I don't think that one was at the reunion. Dave | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Actually, Mark, I'm really impressed with the range on your plots. Its adds credence to the theory that maybe these things really do open up over time with use, and I recall that yours might possible have seen more use in its life than any of the other originals. OFC No. 5 wants to be just like original No. 43 when it grows up. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | ". . Its adds credence to the theory that maybe these things really do open up over time with use . ." OR, . . that the Originals (or this one in particular) just sounds that much "different" from the Re-Issues . . . The "opening up" theory would require a plot from when the guitar was NEW to be used as a comparison to substantiate it . . . | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | Tup, why do you want a plot of #42? Cliff, you're right. Without a plot of the originals made when they were new, there's no way of knowing short of waiting 30 years. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | Wouldn't take THAT long. More like 29 years, 10 months . . . | ||
| cholloway |
Joined: March 2005 Posts: 2793 Location: Atlanta, GA. | Slothead #45 was at the reunion in Sept '05. Its results: A:Freq Resp 2/1 X:182.4022 Hz Y:-35.305 dB B:Freq Resp 2/1 X:78.2582 Hz Y:-36.552 dB Its Freq Resp was originally recorded as 92. Whatever it all means! | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Marks says he's looking for the original scan on No. 43. This will be enlightening if he can locate it. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | I don't think that the machine was "around" back then . . . | ||
| Charlie Ramon |
Joined: August 2004 Posts: 709 Location: Germany | The lowest response frequency of #43 moved from 93 Hz to 74 Hz, #45 moved from 92 Hz to 78 Hz. I think this supports the "sound development theory". Looks that they tend to become more bassy. Karl PS. OFC #10 is expected to arrive on Friday. | ||
| elginacres |
Joined: July 2005 Posts: 1609 Location: Colorado | I do not have a plot like the one done a couple years ago. Back then they measured time with a calendar and motion/distance in cubits. Only additional information I have about this guitar pertaining to this topic is its fundamental resonant frequency - which is 93Hz. If it has opened up - I cannot prove it...not sure if it has...Over the 20 years or so I've had the guitar...the change would be so slow - I would not be able to tell - sounded good then - sounds good now. Professor - I'm still betting your OFC sounds better - I'm trusting 30 years of learning leads to something better....I'd bet at the very least the OFC is louder. I have personally found the best sounding guitars are the ones in which the PLAYER actually hits the notes precisely in time and in tune...a novel concept. Several years ago Phil Keaggy played #43 for ten minutes..trust me - it sounded much better then. You also have to remember - when the originals were made - it was a progression over time - with educated experimentation involved in the process (Bill - tell me if this is incorrect). The great art form is ....what response do we need from the guitar to make it sound subjectively good (measurement by one player with bias)...and what science in the process should be there - to consistently make a lot of them objectively good (measurement by lots of of players without bias). Man...can you tell I'm a HS principal in the summer with nothing to do but write? I gotta get back to work....maybe I'll buy some string tubes. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | Mark; In answer to your PM: Yes I did take some pics of the "Master Printout" at the SlotHead Reunion in '05. However, since it was so large (about 3' wide x 10' long) and that it was laid-out on a table, the "overall" pic doesn't show any readable details. By looking at some of the "close-up" pics it show various dimensions, weights, dates and such for each guitar. It lists the "Resonant Frequency" for each guitar, but that's about the extent of anything along those lines . . . ![]() | ||
| stonebobbo |
Joined: August 2002 Posts: 8307 Location: Tennessee | Originally posted by Charlie Ramon: But the higher frequencies may also have moved up ... all of the OFCs seem to at most be in the mid-160s, and the originals are now in the 180s and 190s. I wonder if the volume also picks up based on the lower -dbs of the originals? The lowest response frequency of #43 moved from 93 Hz to 74 Hz, #45 moved from 92 Hz to 78 Hz. I think this supports the "sound development theory". Looks that they tend to become more bassy. Karl PS. OFC #10 is expected to arrive on Friday. Guess I'll just play the crap out of mine for the next 20-30 years and then see if I can get another plot. Check back, I'll let you know. :cool: The anticipation must be killing you Karl. ;) | ||
| elginacres |
Joined: July 2005 Posts: 1609 Location: Colorado | Thanks Cliff - great piece of history you have there...folks - I cannot jump to the conclusion that the resonant frequency in 1976 equates to the A and B measurements a couple years ago...it might - but I dunno...but it was freaky watching Darren run the video plot of the geetar...as Cliff suggested - - even Darren admitted through video analysis this particular guitar has some unique sound signatures...so be it! I'm guessing we need a prof. interp. Even if it opened up - it still doesn't help me play an Ab augmented flatted 9th with and F natural on the low E string! | ||
| Charlie Ramon |
Joined: August 2004 Posts: 709 Location: Germany | #10 arrived safely with the carbon case. It looks and sounds tremendous. Thanks Al for the many hours you put into that guitar and all the other stuff. Dave, I will send you the laser plot. Jerome, Tom and I took some pics on the Imperial Castle of Nuremberg. There was a lot of interest in our guitars, especially from some US tourists. They were very proud to hear that these nice guitars were built in their home country. Karl | ||
| Tim in Tidewater |
Joined: December 2005 Posts: 1234 Location: Tidal Mudflats of Virginia | Dave, Email sent your way for #9. Now we just need to get Darren or Rick to let us have a copy of our respective 47RI's scans. Tim | ||
| Northcountry |
| Joined: February 2004 Posts: 2487 | This is great for Ovations, nice to brag higher numbers or what-have-you but I am curious if anyone has the numbers for a high end Taylor, Martin, Gibson acoustic and so on?? I would be curious to see comparitive numbers between the traditional guitars themselves and in comparison to the Ovations. I know little of this technology so I suppose these numbers on the traditional guitars my exist somewhere......???... but I have only ever heard Ovation sporting the frequency results on thier guitars. By the way, Nice photo's gentlemen! | ||
| LBJ |
Joined: March 2007 Posts: 665 Location: Tychy, Poland | i've seen a plot from a samick D-1, guitar for $100 and it had 83-155 hz range. but it doesn't mean anything. that guitar sounded like a crap no matter what plot said. | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | Personally I don't think the numbers mean crap. It's like the torque curve on a Ford F-350 pickup truck. Nice to look at when your shopping for a new vehicle, but I doubt it ever crosses your mind when you're hauling the boat out of the water. Don't get me wrong, it's very good that the company has this capability and maybe it can weed out the extremes, but I think it's only relevent to help visualize that identical guitars in fact perform more or less the same on the vibrometer. They have measured some benchmark guitars (read "D28") and found similar patterns, or so I've heard. But I don't think you're gonna look at a bunch of plots and say the Gibson sounds like it does because of these peaks, and the Collings sounds like this because of that slope, etc. The only definitive correlation I have seen is a plot of a high end Taylor. The shape of the plot distinctly resembled a limp penis. Dave | ||
| LBJ |
Joined: March 2007 Posts: 665 Location: Tychy, Poland | For me, in this particular case (samick) numbers didn't mean anything. guitar sounded great when you strummed or picked it without pressing the strings to fretboard. but if you wanted to play a barre chord, this guitar's "distinctive" sound turned into a flat crappy sound of a cheap guitar. i'm sure that there are ways to make plot look great, not neccesairly to make guitar sound great. and about the numbers. you could say that Lamborgini Murcielago is much faster than Lancer Evolution based on numbers Lambo has 6,2 V12 engine, rear wheel drive and 580hp, and EVO has 340HP (mr340), 2 liter engine and costs 10% of Murcielago. And still, head to head on track EVO Wins. and still you need a really good driver (or guitar player) to use everything that car/guitar gives. | ||
| cholloway |
Joined: March 2005 Posts: 2793 Location: Atlanta, GA. | Finally scanned the plot of Slothead #0045. I emailed Dave a Hi-Res copy. ![]() | ||
