Which Electronics Are Best?
Posted 2006-04-27 12:39 PM (#257190 - in reply to #257165)
Subject: Re: Which Electronics Are Best?
OK MISTER WIZARD. So you have to go to TWO different links. One for the OP series and one for the Pre OP series. EXCUUUUSE Me !!!!!
Posted 2006-04-27 1:44 PM (#257191 - in reply to #257165)
My Optima doesn't work without a dummy plug. I know, it usually has a dummy operator, too. I thought that I was leaving the plug in, but the battery seems to drain when the plug is out. It just has never been a big enough deal for me to bother with. I just take out the battery whenever I pull the plug.
Posted 2006-04-27 2:30 PM (#257192 - in reply to #257165)
Mark,
Way to beat about 10 other members to the punch.
To be honest I don't change my settings much so except for the onboard tuner feature in the OP series, I would just as soon have Two knobs,( Tone & Volume), or the stacked knobs. But what do I know, I just like to play and let a good Sound Tech take care of the rest. :)
Posted 2006-04-27 2:41 PM (#257193 - in reply to #257165)
I'm the sound tech, band and audience. I'm best at the audience part.
Posted 2006-04-27 4:43 PM (#257194 - in reply to #257165)
EXCUUUUSE Me !!!!!
:) Made me smile.
Does the Optima need a dummy plug? I'm not sure that mine does, I'll have to check it tonight.
I know that with my 6778LX (OP-Pro), I had to be careful which XLR cable I used. Lately I've been playing my 1581, and it doesn't seem to matter which cable I use, it always works. I'll test it with a cable I know is not pin1>shell.
Mark, Cliff's right (life is full of wonders, isn't it?) about checking the jack. That's the one place there could be enough of a short to kill the battery without noticeably affecting the sound. It may be fine when there's a plug in it, but shorted when you unplug.
Posted 2006-04-27 5:33 PM (#257195 - in reply to #257165)
Thanks, friends, for your comments. I have the Op-Pro and Optima ranking pretty well figured, but who can tell me how they stack up against the original two knob stereo FET set up? I would like to know as it may have some bearing on choosing a U681 with the Op-Pro over an Adamas I or II reissue two-knobber.
TexasDoc
Posted 2006-04-27 6:50 PM (#257196 - in reply to #257165)
Another difference: The Op50 and Optima have the notch filter, the OpPro doesn't.
Posted 2006-04-27 6:54 PM (#257197 - in reply to #257165)
Thanks, tten. The OP 40 and several of my Acoustasonic Jr amps also have the notch filter feature, but I have to admit I seldom use it except when I'm facing an amp and it is usually to eliminate a low A feedback issue in my studio. It has never been a problem anywhere else.
Posted 2006-04-28 12:39 AM (#257198 - in reply to #257165)
Professor - With all due respect, the U681 and the I/II reissues are two completely different guitars in many regards. There are a HELL of a lot bigger differences between them than the pre-amps. For one thing, the U is a 12-fret wideneck. The I/II are 14-fret standard neck. That's a major difference. It just seems to me that choosing between them based on pre-amp would be like choosing a new car between a sedan and an SUV and you choose the SUV because it has a better CD player. Just my opinion.
Posted 2006-04-28 4:52 AM (#257199 - in reply to #257165)
The reissue Adamas I and II have the two knob pre-amp, probably even better than the original. Probably more than you will ever need.
EQ, XLR, tuner, etc., are the advantages of the OP-Pro.
Agree with Dave, don't worry about the pre-amp, make your decision based on the guitar.
Posted 2006-04-28 8:59 AM (#257200 - in reply to #257165)
It makes a difference in how the guitar will be used. I was playing my 1537 last night at church and plugged straight thru the PA, it doesn't have a great sound. You've got to remember that the electronics are a 30 year old design --- excellent for the time, but surpassed today.
I've got 2 guitars with OP24's --- Big Blue and the 87 C. Both are much better plugged in.
But the 1537 has a great acoustic sound. If it were my only guitar to play, I'd order up the redesigned 2 knob electronics that Ovation is using on it's reissues (might do that anyway, but I'm not real certain that the 1537 is going to get "plugged in" use. Might just remove the battery and keep it as an acoustic only guitar).
Posted 2006-04-28 9:18 AM (#257201 - in reply to #257165)
Paul, I had the new electronics put in my 1547. HUGE FULL sound....just totally blows away the original electronics IMHO. Well worth the upgrade if you ever plan to play it plugged in.
Since the reissues will eventually go away, I wonder how long they will have spare electronics for it? I am definately glad I performed the upgrade.
Posted 2006-04-28 9:39 AM (#257202 - in reply to #257165)
T28, which electronics did you have put in ???
Posted 2006-04-28 10:19 AM (#257203 - in reply to #257165)
The Adamas reissue electronics that apparently are direct replacements for the old 2 knobbers.
Posted 2006-04-28 10:28 AM (#257204 - in reply to #257165)
Wouldn't it have been cheaper to just put the new knobs on?
Posted 2006-04-28 10:47 AM (#257205 - in reply to #257165)
Silly wabbit.
Posted 2006-04-28 11:26 AM (#257206 - in reply to #257165)
I may be a silly wabbit, but I'm not going to Alcatwaz!*
*Hare Brush
Posted 2006-04-28 4:24 PM (#257207 - in reply to #257165)
and I'm not going to CT.
PHHHHSSSSTTT
no wait....that's not right....I do want to go to CT.
Curse you Wabbit....you win this round.
Posted 2006-04-28 4:59 PM (#257208 - in reply to #257165)
Stephen, come to CT.
You can clap for me when I win the guitar giveaway!
Posted 2006-04-28 5:14 PM (#257209 - in reply to #257165)
I hear they are giving away a FRG #47 :eek:
tpa
Posted 2006-04-29 2:54 PM (#257210 - in reply to #257165)
The Optima sounds better than the OP-20 in my previous Ovation. Especially the attack. A better pick-up could be part of the explanation for that.
Both have been quite noisy with hum.
Jacob
Posted 2006-05-03 12:29 AM (#257211 - in reply to #257165)
February 2006
Backing it up a bit... what's the deal with the special OP50 XLR cable?
My dream Adamas has been a textured top W597 with an OP50, so my dream might be shattering...
