Adjusted the action, now sounds dead
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Originally posted by Standingovation: I use down guys and load transfer rigging everyday, Dave...just trying stimulate a little discussion...you WERE supposed to play along. Originally posted by Jeff W.: Jeff, Jeff, Jeff ... you keep this up and we'll have to send you back to engineering school. Draw a vector diagram of the forces and you'll see that what you said is not quite correct. But what do I know? I'm just an idiot who corrects other people for a living. Dave thus creating opposition limiting the ability of the top to vibrate. Now, where did I put those string tubes? | ||
| Sleepy Eyes McGee |
Joined: June 2005 Posts: 231 Location: N.J. | :eek: :eek: :eek: Holy Crap.!!! Doesnt anybody just PLAY anymore ????? :p ;) :) | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | Originally posted by Jeff W.: Oh... I use down guys and load transfer rigging everyday, Dave...just trying stimulate a little discussion...you WERE supposed to play along. well, alright then... | ||
| Standingovation |
Joined: June 2002 Posts: 6202 Location: Phoenix AZ | Jeff, we need some kind of "code word" to signal when we're going into action. How about "Bosco". Dave | ||
| MWoody |
Joined: December 2003 Posts: 13997 Location: Upper Left USA | I thought the old phrase was "shut up, Witko!". It seemed to work before. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | No. . . . that's what's uttered when the ball is strapped into his mouth . . . . | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | My fault. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Besides, Bosco might be someone's ATM code. | ||
| bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | If you MUST have Les Paul action send it to the Service Dept. I went through this with my Std. Elite LX. I sent it in a month before the tour. They reset the neck and handed it back to me when I arrived at the factory. It did the trick. If you're that fussy about set-up (and you're allowed...it's YOUR guitar)then get it set up by the best. It'll cost you, but you'll love it when you get it back! John <>{ | ||
| Old Applause Owner |
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | What I'd be curious about is how they do it on an LX. Both of mine arrived with action significantly higher than the manual calls out. Removing a shim brought it into specification, but, of course, the sound suffered a bit. (I removed a shim on my 1771LX since the post earlier today) I reopen this with trepidation, but....I don't think the string really "restricts" the top's movement....it simply transmits the string's vibration to the top, the more perpendicular the angle(less loss of energy), the better. Shouldn't matter if it is a pinned bridge or a through bridge. Roger | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | Here I go again ... ;) just kidding That's pretty much correct OAO | ||
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | Thanks....guess I should READ the intervening posts THOROUGHLY..... Roger | ||
| Eman |
Joined: October 2002 Posts: 153 Location: Huntington Beach, CA | I wish I had this information a while ago. I sold a probably perfectly good CL shallow body just because it sounded muffled and weak. It had been lowered to the max by the local Ovation repair guy. I could have handled higher action but didn't know any better and just blamed the sound on the shallow bowl. Now I finally get what CWK2 was talking about when I blasted shallow bowls a couple of years back. Now I have another CL and the action is high. I love the sound as is. I guess I can experiment with the shims but if I lose that great sound, what can I do??? A neck reset on a brand new instrument doesn't seem reasonable. How can the angle of the string from bridge to saddle be increased? Also, does proximity of string to sound hole have any bearing on sound quality? Is there an optimum distance to the sound hole for best sound? I'd be interested to hear from the engineers on this one. Thanks. Eman. | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | Originally posted by Eman: answer to your first question: I don't know of any practical way to accomplish this. How can the angle of the string from bridge to saddle be increased? Also, does proximity of string to sound hole have any bearing on sound quality? Is there an optimum distance to the sound hole for best sound? I'd be interested to hear from the engineers on this one. Thanks. Eman. Before answering your second question I'll offer a couple of observations. First, multihole models don't have a 'soundhole' per say (also think about Tacomas'). Second, if you were to prevent the top from vibrating (press down with your palm) you pretty much kill the sound. Based on these two things I would suggest that the soundhole is there for decoration. It size (summ area of the openings) affects the resonant characteristics of the body chamber. It's position is pretty irrelevant. Answer to your third question will likely fuel the rest of this thread and the onging discussions between the centrhole, multihole camps for the foreseable future. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | Contact the customer service guys at Ovation. They can answer your questions. | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | At the next tour I am going to personaly ask an engineer about this. | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | And if you're not careful, you'll wake up the Temp. Shhhh. | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | I don't doubt that it makes a difference. But is it a quantifiable difference? Would it take Spock's tricorder to measure the change in tone & volume? | ||
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | First, you need to define tone and volume. To truly define tone you need to do a full frequency spectrum analysis of the results of various notes, chords, etc. Several guitars, known "good" guitars for tone, irrespective of brand would be good. Perhaps then, one could define what frequencies are pleasant and desirable and what frequencies are NOT. Volume is easier, decibel readings at a series of set distances from each guitar should suffice. I believe a lot of this type of work was done prior to the first Ovations, and again before the first Adamii. Look in "The Book". I doubt that string distance from the soundhole, in and of itself, makes any difference, only that the distance needs to be fairly short for optimum transmission of vibration through the bridge to the top(plus, the more perpendicular the string to the top, the more efficient the vibration transmission). Eman, I'd experiment with shims to optimize action to sound....you can make thicknesses in-between the factory shims with styrene strip plastic. Or make ONE shim the correct thickness and not add two or three. Roger | ||
