Capo?
Posted 2011-04-06 11:50 AM (#353931 - in reply to #353906)
Subject: Re: Capo?
I have maybe a dozen capos of various makes, but prefer an old Victor model that I've used regularly for the past 20 years. These days, we play many songs that modulate from one key to another, so capos just make transpositions even more complex.
I also have to disagree with Flysig on placement of the capo. I find that when the capo is placed directly behind the fret, there is a tendancy to pull the string around the fret which increases the string bend angle and affects intonation. I find intonation is less impacted by placing the capo in the middle of the fret. In theory, the basis for this reasoning may be rooted in physics. This isn't my specialty, so maybe some engineer can explain this better than me, but the theory is relatively simple. The shortest distance between two objects (the frets) is a straight line (the tuned string). To minimize the capo's impact on string intonation, the string should remain as close to straight as possible. Ideally, Stephen's suggestion of placing the capo directly on the fret would result in the least amount of bend angle and the string would remain about as close to straight as possible. The next option would be to split the difference between the frets, which is what I do. Placement of the capo directly behind the fret creates a near 90 degree bend of the string as the string wraps around the fret. Another factor is the width of the capo bar that comes in contact with the string. The wider the bar, the greater the likelihood that the string will now have compound bend angles at the capo, one in front of the bar and one behind it. Adding the bend on the fret itself, there are now three angles changing the string from being straight.
I've tried Stephen's method, but find that the capo gets in the way of my hand in forming chords close to the capo. I'll give up a little compromise in intonation (imperceptable to most listeners in live performances) in order to avoid the capo from interfering with my left hand technique.
Posted 2011-04-06 12:15 PM (#353932 - in reply to #353906)
Subject: Re: Capo?
Hence the Elliott. They have even come out with a superslim model which helps with the issue you mentioned.
but overall I agree. If I don't place it directly on the fret I tend to position it near the middle.
mlevinedc
Posted 2011-04-10 10:58 PM (#353933 - in reply to #353906)
Subject: Re: Capo?
November 2007
My sincere thanks to everyone who replied. :p
rick endres
Posted 2011-04-12 8:43 AM (#353934 - in reply to #353906)
Subject: Re: Capo?
August 2005
I like Dunlop Trigger capos. They're fast and don't affect intonation too badly, at least on my guitars. And they're durable; I've had the same one for ten years. I liked Kysers okay, but I was going through one every six months; the springs were breaking.
Darkbar
Posted 2011-04-12 2:33 PM (#353935 - in reply to #353906)
Subject: Re: Capo?
January 2009
Rick- you should add a link to your website at the bottom of your posts. People like to know this stuff. Here ya go..... Rick Endres
sycamore
Posted 2011-04-15 11:58 AM (#353936 - in reply to #353906)
Subject: Re: Capo?
March 2007
Interesting how many people use a Shubb. My choice too, before I ever came to the OFC.
Jargon
Posted 2011-04-16 12:10 AM (#353937 - in reply to #353906)
Subject: Re: Capo?
January 2011
I've used a number of capos through the years. Before I bought my first capo, I had opportunities to use capos that were big, heavy and cumbersome. So when it came time to buy my own capo, I bought a Dunlop Toggle Action capo . I liked that capo because it was so small it could fit in my shirt or jeans pocket without anyone noticing it's there. So I actually carried it in my pocket wherever I went.
Later I bought a Kyser Quick Change capo . I liked the fact that I could use it using only my right hand. So it became my favorite for a while until I bought a Dunlop Trigger capo . The Dunlop capo was similar to the Kyser in the one-hand operation. The difference is that the Dunlop is operated using the left hand instead of the right. But these two capos have a common disadvantage: you need a lot of grip strength to use them.
My current favorite capo is the Planet Waves NS Dual-Action capo . Using it requires only one hand, the left hand. But you don't need to have a strong grip to use it. Even better, the tension is adjustable. So you could prevent the strings from going sharp. The only disadvantage of that capo is that it's not very pocketable. So for that I also bought its smaller sibling, the Planet Waves NS capo . These two Planet Waves capos are what I use now.
Posted 2011-04-16 12:38 AM (#353938 - in reply to #353906)
Subject: Re: Capo?
Boy, I haven't thought of that Dunlop Quick Change in a long time.
I've used Kysers for years, but on a couple of guitars use Shubbs.
For 6 strings, I'll use whatever is handy. It's 12 strings where I have a problem. I use Shubbs, but I've got to clamp it down really hard to get all the strings to ring clearly.
Anybody else have a problem like that? What do you do about it?
Posted 2011-04-16 4:14 AM (#353939 - in reply to #353906)
Subject: Re: Capo?
I use Shubbs pretty much all the time, except on the 12. I find the wide Kyser snugged up as close to the fret as possible works best of all the different ones I've tried. On my guitar anyway ... I think your Big Blue has a more C shape to it than my 6759.
ignimbyte
Posted 2011-04-16 9:56 AM (#353940 - in reply to #353906)
Subject: Re: Capo?
July 2004
I use the Kyser quick change on my guitars ... seven years later, and I haven't found one reason to complain about them. :)
Posted 2011-04-16 7:36 PM (#353941 - in reply to #353906)
Subject: Re: Capo?
Elliot works beautifully on every 12 string (including the baritone) that I have tried it on.
hwebster
Posted 2011-04-17 11:11 AM (#353942 - in reply to #353906)
Subject: Re: Capo?
June 2005
Planet Waves, don't need to have a strong grip to use it and the tension is adjustable, you love it.
nervous
Posted 2011-04-21 8:28 AM (#353943 - in reply to #353906)
Subject: Re: Capo?
May 2009
Another vote for the Planet Waves. Well made, good looking, quick & easy to use. My only choice now. Very hard to beat, especially for their price.
PEZ
Posted 2011-04-23 2:56 PM (#353944 - in reply to #353906)
Subject: Re: Capo?
July 2003
I use a Kyser strings I Adamas 1818 strings or Dean Markley Alcamy Goldenbronze
PEZ
Posted 2011-04-23 2:58 PM (#353945 - in reply to #353906)
Subject: Re: Capo?
July 2003
Posted 2011-04-24 9:46 AM (#353946 - in reply to #353906)
Subject: Re: Capo?
Elliott then keyser then shubb
the keyser is good for a quick key change or just to find the key when figuring out a song.
I like the Green Keyser 5 string capo that gives you the fake drop D.
I've got several Elliotts but can never find them all at the same time.
Posted 2011-04-24 2:05 PM (#353947 - in reply to #353906)
Subject: Re: Capo?
Ha Ha...
Beal, that is why you slide the Elliott's above the nut when not in use (but at least you can easily find them).
slothead
Posted 2011-04-29 4:47 AM (#353948 - in reply to #353906)
Subject: Re: Capo?
July 2004
exp strings dunlop capo or kyser
