Lost in all these models. What to buy?
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | The red Balladeer would be my choice. I've given up on black guitars, too hard to keep clean. | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | True...unless they're a textured top like the Adamas or EliteT. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Yep, the shiny one's show every speck, print and sweat drop... | ||
| Gallerinski |
| Joined: May 2008 Posts: 4996 Location: Phoenix AZ | Black guitars are like cars, a little tougher to keep clean. But when clean and shiny they DO look great. | ||
| rededdie |
Joined: January 2006 Posts: 387 Location: Whitecourt, Ab | they say black makes you look slimmer... doesn't work for me | ||
| Bloodshed |
Joined: April 2009 Posts: 8 Location: France | I know the problems of black guitar 'cause I have one but I think it looks great. Anyway I changed my mind, I just ordered the Ovation 2778AX-NEB Standard Elite ! I decided to give a luck to the multi-hole design. Plus it looks really great with the new england burst color. And if I can't stand anymore with this, I just have to return the guitar to get refunded. So here my new guitar! Thanks you all for your precious advices. ;) | ||
| BT717 |
Joined: October 2007 Posts: 2711 Location: Vernon CT | Congrats and Enjoy!!! :) | ||
| sypolog |
Joined: April 2009 Posts: 130 Location: London, UK | The look and finish on a far eastern model could well be 'better'. But the SOUND, the SOUND... | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Originally posted by Gallerinski: Absolutely true. Black guitars are like cars, a little tougher to keep clean. But when clean and shiny they DO look great. But I don't have time to keep my car (or my bike, for that matter) clean, either... | ||
| Bloodshed |
Joined: April 2009 Posts: 8 Location: France | Originally posted by FlicKreno aka Solid Top: How do I adjust the guitar? I have to bring it to a specialized shop or can I do it myself? You are talking about the tuning of the neck, right?One thing : ya will need to adjust the guitar , which is EASY to do and makes a BIG Difference when ya play it. ( that goes for any guitar ) When ya have the guitar , I`m sure someone here will tell ya how. | ||
| marenostrum |
Joined: August 2007 Posts: 1008 Location: Tuscany, Italy | Congrats for your new guitar. I guess you have to control the action first. In case it does not suit you just remove one or both shims (under the saddle) to lower it. Normaly I do this at the first string change. Neck should be Ok as setted by the factory, but check for straightness and act carefully with the trus rod to correct it (just in case....). It's an easy operation you can do by yourself. Otherwise go to your local music shop and ask them to do the job, if in need of. Riccardo | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | When I was in Hong Kong in February I got to play some east asian ovations, and I didn't compare the celebs to the ovations. This would be an interesting comparison. | ||
| FlySig |
Joined: October 2005 Posts: 4089 Location: Utah | Originally posted by Bloodshed: Congrats on a great guitar. You will love it. How do I adjust the guitar? I have to bring it to a specialized shop or can I do it myself? You are talking about the tuning of the neck, right? The action is very easy to adjust. There are numerous websites that show you how. Basically, you want to get the strings properly positioned over the neck. So, the first thing to do is just play your guitar for a week and let the wood adjust to your climate. The humidity will affect the wood, so it has to get used to your house. If you are in a very dry place you should get a humidifier. After a week, check the setup. It is easy. Hold the thickest string down at the first fret and also between the 13th and 14th frets. The string will now be a straight line. Look under the string at the 6th fret. There should be a very very small space that you almost cannot even see. If the gap is large, you should tighten the truss rod. Only make a very small adjustment and then wait for a day to see how it settles. Then make another adjustment if needed. If the string is touching at the 6th fret, you have to loosen the truss rod. When the truss rod is adjusted correctly, you can then remove or add shims under the bridge. If the strings are too low, they will buzz or sound choked when you play up at the highest frets. Add a shim if that happens. If the strings are too high, it makes it harder to play. Remove a shim. Most people find that removing one shim from a new Ovation makes it play easier. It is a simple thing to try. | ||
| Bloodshed |
Joined: April 2009 Posts: 8 Location: France | Hello, I just received the Ovation 2778 AX NEB, it is really beautiful! And the sound... clear, full. This is really the greatest guitar I have ever played. But I meet some difficulty with the case I bought, the 8158 ( http://www.thomann.de/fr/ovation_ssb_case.htm ). On the article page it is written "for Ovation Deep & Midth Bowl". So I supposed the 2778 AX (Deep Contour) is ok? But It seems to be more difficult too close it than it should, when the guitar is into. I have to force a bit on it. Is it normal or should I get another case? Thanks | ||
| Gallerinski |
| Joined: May 2008 Posts: 4996 Location: Phoenix AZ | 8158 is the correct case. Glad you like the guitar. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | I really like the 'burst on that guitar. Post some pics of the actual guitar.... | ||
