1992 collectors series problems!
timiko
Posted 2013-06-21 5:47 PM (#472749)
Subject: 1992 collectors series problems!
April 2011
I need some advice, I have a 92 collectors series that needs a fret job but is also getting some slight bowl separation nothing bad but its got me concerned, any ideas? should I send it back to the mothership? and if so who do I contact? thanks!
Posted 2013-06-21 10:06 PM (#472753 - in reply to #472749)
Subject: Re: 1992 collectors series problems!
We all say the you want to contact John Budny and Kim Keller.
But to start you should just converse with whomever you get.
Follow the instructions here...
http://www.ovationguitars.com/support/customer_service
I just called the USA Ovation 7575 number to make sure that it works...
It does. (I just called to make sure that those numbers are current)
Posted 2013-06-22 12:21 PM (#472757 - in reply to #472749)
Can you describe the bowl separation, or better yet post some pictures of it?
timiko
Posted 2013-06-23 6:24 PM (#472796 - in reply to #472749)
April 2011
I dont I have anything that would take a closeup of it so you could see it but I'll try and describe it for ya. its about 10" long and runs just above the electonics, a little bit larger just around the electronics and feathers out to each side till you cant see it anymore. also just slightly see it around the end strap button. also thanks arthur for the info that helps alot!
Edited by timiko 2013-06-23 6:43 PM
