i cant remove my saddle..
mfo
Posted 2003-12-10 2:43 AM (#199695)
Subject: i cant remove my saddle..
hi, i want to lower my action, but i can't seem to take my saddle out... is there anything special that i need to do to take it off??
its a Korean Ovation Celebrity Deluxe CS267 btw...
Paul Blanchard
Posted 2003-12-10 9:40 AM (#199696 - in reply to #199695)
Subject: Re: i cant remove my saddle..
The black pins on either side of the saddle must be gripped and pulled out to release the saddle. Sometimes they stick in there pretty well. You can try removing the back plate and reaching your hand in to push them up from below. And since it is quite possible that one reason the action is high is that the neck needs some adjustment, you can attend to that while you have your hand inside the guitar IF you have the proper hex key.
Posted 2003-12-10 10:00 AM (#199697 - in reply to #199695)
The Celebs use the thinline pickup, so no pins. It's probably just tight in the slot, try carefully gripping it with some needlenose pliers. Remember that the pickup is integral with the saddle so the only way to lower the action is to remove shims, you can't remove material from the base of the saddle. If there's no shims then the saddle-slot will need to be routed a little deeper. However as the neck set on some imports is pretty shallow this may cause too shallow a break-angle at the bridge, so take care.
Posted 2003-12-10 12:08 PM (#199698 - in reply to #199695)
I had a similar situation with the thinline pickup. Maybe this is not the recommended course of action, but I lightly sanded the TOP of the saddle to achieve the desired action. Dave
