Lead Booster?
numbfingers
Posted 2008-01-28 10:01 AM (#58278 - in reply to #58253)
Subject: Re: Lead Booster?
Duncan has something that might work. I haven't tried it, just seen pictures- not sure if it would be good for acoustic.
Duncan Pickup Booster
Reviews
Posted 2008-01-28 10:06 AM (#58279 - in reply to #58253)
The Duncan is basically the same as the MXR Micro-Amp, except that the Duncan has a few dB extra gain.
Posted 2008-01-28 10:50 AM (#58280 - in reply to #58253)
I've only seen the Duncan used with electrics. I don't say it wouldn't work with a piezo, probably would ... but the shark / sansamp combo may be what your asking for.
dobro
Posted 2008-01-28 1:49 PM (#58281 - in reply to #58253)
I'm looking forward to trying the Nobels pedal. I imagine that I can dial in a tone setting for lead that will be light on bass (limiting feedback) so that when I stomp, I'll get a little boost for playing above middle C.
Posted 2008-01-28 4:34 PM (#58282 - in reply to #58253)
The Nobel pedal is supposedly the most used OD pedal in Nashville. It has tone controls so it's more adaptable than the Duncan. The virtue of the Duncan is that is a tone-neutral boost pedal. On/Off - you takes your choice.
I've got a Nobel A/B box and it is SILENT - their stuff is excellent.
dobro
Posted 2008-01-28 4:52 PM (#58283 - in reply to #58253)
That is VERY good to hear. The Adamas is SO dynamic that I find myself in critical need of some A/B gizmo. I am attracted to a stomp box over a volume pedal since a VP still has to be set and regulated somewhat. During a tune like "Spain" there simply is NO time whatever between, say, unison lines and comping back to double-stops on to solos...
Posted 2008-01-28 6:25 PM (#58284 - in reply to #58253)
Stephen, is this Nobels pedal the same as yours that I tried a while ago? If so, I thought the Jaques Tube Blower worked better for me after comparing them head to head.
Posted 2008-01-28 7:03 PM (#58285 - in reply to #58253)
I thought China was the lead booster ???
Posted 2008-01-28 8:30 PM (#58286 - in reply to #58253)
Won't the Tube Blower and Nobels color the sound? While the Sansamp be a clean boost?
dobro
Posted 2008-01-28 9:07 PM (#58287 - in reply to #58253)
Temp sez not: the specs on the Nobels suggest that it is "transparent" and quiet. Will soon try it and submit a report!
Posted 2008-01-28 11:15 PM (#58288 - in reply to #58253)
No, Dobro is looking at a pre/booster and the Nobels I have (that you tried out) is the OD that Schroeder was talking about.
dobro
Posted 2008-01-29 10:41 PM (#58289 - in reply to #58253)
OK, now what sort of WAH WAH pedal do y'all use? I imagine there is a special one that goes best with a slot head, right?
Posted 2008-01-30 5:34 PM (#58290 - in reply to #58253)
Dunlop Cry Baby 535q. Simple, some tone options, been around a long time, and built to last, but heavy to lug around. It is used only sparingly, so I hook it up alongside the pedal board when required in lieu of keeping it on the board.
