Location: Cork, Ireland | seesquare - 2021-01-30 11:12 PM
RE: bowl bend protocol, as outlined above:
That pedantic style sure sounds like something I would write. I did a bowl bend on an 1113 Classical several years ago, & it had the hand-laid fiberglass bowl, which probably made the adjustment more feasible.
The method above is generally accurate. Above all, go slow. It won't take much angle change to make a big difference. Making the bowl-holding jig will be the biggest challenge. If you want to take a general shot at whether the bowl will bend, just put a bungee cord on the peghead & tail strap button, & let it sit for a few days. If the neck takes a different "set", after the tension is removed, & left to it's own device for a day, you just might be in business.
Best of luck!
just to clarify the bungee cord method: is it like this?
(Bowl Bend.jpg)
Attachments ----------------
Bowl Bend.jpg (47KB - 0 downloads)
Location: Cork, Ireland | OK, after a beautiful 33-year relationship, this baby will now bend to my will. what do you think of my jig? A glass garden table and some luggage straps, books to keep the body from tilting. A pencil mark on the mitre block showes my starting point.
I was thinking about the various arrangements for supporting the round back and then I thought "the front is not round".
Now cooling, with fingers and toes crossed.
Does anyone have a protocol for bowl unbending?
Edited by sycamore 2021-05-24 7:03 AM
Location: Upper Left USA | Take a look at this album and see what I did. Photo albums (ovationfanclub.com) This is all you need. Photo albums (ovationfanclub.com)
Edited by MWoody 2021-05-24 11:40 AM
Location: Pueblo West, CO | sycamore - 2021-05-24 5:02 AM
A glass garden table...
I would be careful not to overheat the glass lest it shatter. |
Alternatively, I could set the kitchen table on fire...
(Bowl Bend 2.jpg)
Bowl Bend 2.jpg (29KB - 0 downloads)
Location: Pueblo West, CO | I should also add that you can only perform bowl bend on a cloth bowl.
SMC bowls can't be re-shaped. |
Location: Cork, Ireland | Mine went OK. It did not bend as much as I thought but I've decided it's enough. I am still tuning it a semitone flat and the action is very acceptable now. |
