Bigger da Blog, Better da Job... NOT!
Bluebird
Posted 2011-01-20 11:01 AM (#357385 - in reply to #357360)
Subject: Re: Bigger da Blog, Better da Job... NOT!
Good info, LM...thanks!
Posted 2011-01-20 11:48 AM (#357386 - in reply to #357360)
Thanks for the Lotion Mable.
AstroDan
Posted 2011-01-20 12:42 PM (#357387 - in reply to #357360)
March 2010
I learned soldering to NASA spec's about a hundred years ago in the Marines. Very good post and...
Nice work bumping the post count with the double posts! J/K
Dan
Avatar4550
Posted 2011-01-20 5:12 PM (#357388 - in reply to #357360)
March 2010
Thanks MolonLabe for the excellent soldering tutorial. Being somewhat 'challenged' in my soldering technique, this will come in very handy.
Anything worth doing is worth over doing...
MolonLabe
Posted 2011-01-20 6:39 PM (#357389 - in reply to #357360)
December 2010
... wick is the way to finish it up.
Especially when a circuit board solder pad has a hole for component mounting! Don't forget to check both sides of the board.
BTW, I only use wicking braid for desoldering.
In the case of re-wiring a speaker lug or surface mounting, by following the guidelines, more than satisfactory results can be obtained just using a solder sucker for desoldering.
Beal, if you're using 'Lotion Mable'® for lip balm, don't lick your lips! ;)
Posted 2011-01-20 8:48 PM (#357390 - in reply to #357360)
For the last decade I've been using propane irons. They can go up to 400 degrees in a matter of seconds and you don't need to be tied to a power outlet, so great for mid-gig repairs. I bought a mini fume extractor for the workbench at the store, solder fumes are seriously carcinogenic
Posted 2011-01-20 9:26 PM (#357391 - in reply to #357360)
OK, I won't lick. Must have misread the motion lable.
