Ovation Celebrity Truss Rod Wrench Size?
Mark in Florida
Posted 2021-02-05 3:02 PM (#555035)
Subject: Ovation Celebrity Truss Rod Wrench Size?
October 2020
My neck has some relief, and I don't want to damage the truss rod end.
Thanks
Posted 2021-02-05 3:27 PM (#555036 - in reply to #555035)
Subject: Re: Ovation Celebrity Truss Rod Wrench Size?
3/16"
DetlefMichel
Posted 2021-05-20 9:44 AM (#555573 - in reply to #555035)
May 2011
(I try to explain in english If the trussrod screw was not moved for a long time better remove it completely and add some spray oil on both the screw and the nut and then carefully tighten it again. Thus you can adjust the neck more smoothly and you avoid over-winding because you sense earlier if the screw is too tight.
