saddle question....
CharlieB
Posted 2005-04-01 7:56 PM (#156849)
Subject: saddle question....
January 2004
After a year of playing... maybe 4 sets of strings, I've noticed the high E and B strings have cut a little into the saddle.
Was a bit worried when I started getting some buzz at mid neck, say frets 5-12, on the two plain strings. Relief is about 1/64 or so. Checked high E string elevation at fret 12 and its about 3.5 64ths, under the minimum Ovation suggests (4/64 or 2/32). I remember checking it when new and it was just OVER 2/32 or maybe 4.5/64s and didn't buzz a bit. Yes I have the shims to put in there and can cut any thickness I like from stainless or brass stock too. I like a fairly low action (of course).
Ok, so the only thing I can see is the plain strings have a decent groove in the saddle, whereas the wound strinds have a bit of a scratch in the saddle that they ride in. Even the G string is a bit deeper in the saddle than the D, A and G
I can sorta see that the point of the saddle would tend to get "cut a bit" until there was a bit more surface area to support the string.
The question is.... is this a sort of normal thing?
TWA
Posted 2005-04-01 8:25 PM (#156850 - in reply to #156849)
Subject: Re: saddle question....
The strings will cut into the saddle. As a matter of
fact my saddle on my balladeer had grooves when I bought it from GC. I kept finding it harder to tune from the onboard tuner so I ordered a new one from the Mothership (they sent it for free). The shape was a little different from the original. Had to remove a shim but got the action set to factory specs. The point is now my intonation problems went away. No grooves and action is perfect for my taste.
Thank you Ovation.
Posted 2005-04-01 9:17 PM (#156851 - in reply to #156849)
This is common.
If the cuts effect the break angle of the string over the saddle you should have it replaced/repaired (zap a gap)
