Location: richwood,ohio | i`m having trouble with my sound in the neck p/u.bridge p/u sounds ok.am i right that there are two pole pieces on each p/u?what is the function of each?i`ve adjusted each and just can`t find a happy medium.i`ve even played on another amp and am still not happy.also,i had my amp re-tubed(groove tubes) and biased.sounds very pingy or metalic sounding.i`m wondering if this might be part of the problem.i was happier with the stock tubes.btw,i play into a marshall artist 4203.i`m not a guitar geek but i would appreciate any help.thanks in advance. |
Location: mississippi | go to www . ovation guitar. com and download manual for care and feeding of your ovation it gives a detailed breakdown of the pickups and shims(if applicable) and instructions for set up they also have instructions for all of the different preamp setups on previous guitars hope that helps, if it doesnt im sure some of the guys here can tell you from first hand experience |
Location: richwood,ohio | didn`t find a whole lot there.just got a picture and breakdown on hardware.probably should have a pro set it up. |
