My ADII is a Buzzin'(HELP)
NostrAdamas
Posted 2007-02-10 11:33 AM (#115675)
Subject: My ADII is a Buzzin'(HELP)
October 2004
Hey guys,My ad11 has a fret buzz on the g string only on the E note I have change strings still there,adjusted the truss no help,its only on that string at the e note.Is it a high fret? any advice woul :( d be appriciated. Jeff
www.guitarsoffire.com
ignimbyte
Posted 2007-02-10 1:25 PM (#115676 - in reply to #115675)
Subject: Re: My ADII is a Buzzin'(HELP)
July 2004
Try using a humidifier perhaps?? I understand that it has a carbon top, but it's still constructed with some wooden components in some form or another. That being the case, the guitar is not completely tolerant of changes in temperature and tolerance.
Good luck.
BruDeV
Posted 2007-02-10 6:25 PM (#115677 - in reply to #115675)
Put a straight edge on the frets alongside the g string then rock it back and forth. That will show which fret is high (if any). If it doesn't rock look under the straight edge too see if there is a gap at the fret you're having trouble with.
If the problem just started and you have a high fret, the fret may just need to be reseated.
