1112-4 project
Posted 2014-05-11 3:41 PM (#486541)
Subject: 1112-4 project
this needs the headstock repaired
has some top cracks
typical
first $100 takes it plus shipping
I will try to keep the costs down as low as possible I have a smaller acoustic box it can fit in
what the case? add $75
need a set of tuners? add $25
let me know asap
alpep@lostartvintage.com
Posted 2014-05-12 7:27 AM (#486565 - in reply to #486541)
Subject: Re: 1112-4 project
wow no takers on this one?
I thought someone would jump on this one
Oddball
Posted 2014-05-18 11:45 AM (#486822 - in reply to #486541)
March 2007
FWIW, this exact same break happened to my 1111-4 (crappy case, rough airline handling). The break was above the nut so the fretboard itself was not comprimised. I was low-bucks at the time but worked on boats and had access to epoxy resin. Aligned, clamped, couple of brass screws to hold everything in place, setup (the glue), sanded, amateurishly refinished and set up again (the action). That was 40 years ago and I still play it today. So this is a doable fix if you don't mind a scar tissue showing through the clear-coated neck.
