Question about OP Preamp foot print compatibility
aaronharmon
Posted 2012-05-04 4:37 PM (#454141)
Subject: Question about OP Preamp foot print compatibility
October 2009
I asked this once before and I think I worded it poorly because no one answered me and I am sure that many of you know the answer. I bought an instrument with an OP-24 pre-amp. Which other pre-amp will fit without modification? Will an OP-24+C for example fit? Based on pictures, it looks to be a simple swap. I just want to make sure before I buy one.
Thanks in advance,
Aaron
Posted 2012-05-04 7:17 PM (#454147 - in reply to #454141)
Subject: Re: Question about OP Preamp foot print compatibility
Okay, I'll answer... and if I am wrong someone will correct me.
I Think that the OP-24, OP-24+, OP-24+C, OP-X, and Optima all fit in the same hole.
Or close enough with just a little trim work.
You do realize that these don't drop-in... They come in with a big box in the back, right?
(Just checking)
BTW-- If you go looking for things like "Install OP-24
aaronharmon
Posted 2012-05-04 7:58 PM (#454150 - in reply to #454147)
October 2009
I did not realize that, no. I have changed cans out before to upgrade the newer pre-amps, but never the older stuff. Is it basically the same or is it a lot more work?
Thanks for the help,
Aaron
