Does OP-Pro fit in the can of OP 30?
Chris from Yalova
Posted 2010-06-05 3:38 AM (#370474)
Subject: Does OP-Pro fit in the can of OP 30?
May 2009
I just wonder if anyone has any information or experience with fitting in an OP-Pro into the can of an OP 30?
Would be glad about advice.
Best regards,
Chris
Posted 2010-06-05 4:29 AM (#370475 - in reply to #370474)
Subject: Re: Does OP-Pro fit in the can of OP 30?
No... The connections are different.
The OP-30 has six connector tabs inside.
The OP-Pro has eight connectors.
The cans will fit into the same size hole.
But the two pre-amps will not fit into the others can.
Posted 2010-06-05 10:15 AM (#370476 - in reply to #370474)
But, it is simple and quick to swap the can from one guitar to another. So if you have the can for the OpPro as well as the preamp itself, you can install the whole thing in less than 5 minutes.
