Error encountered in: \\fs1-n02\stor2wc1dfw1\397573\426710\www.ovationfanclub.com\web\content\megabbs\templates\ovationfanclub\fragments\message.asp
Microsoft VBScript runtime error - Type mismatch
Ovation FanClub(tm)
Balladeer Volume & Tone Loss...
Posted 2003-12-26 9:54 AM (#198993)
Subject: Balladeer Volume & Tone Loss...
Posted 2003-12-26 10:39 AM (#198994 - in reply to #198993)
Subject: Re: Balladeer Volume & Tone Loss...
Sounds like it could be component failure in the pre-amp. Piezo crystals tend to either work or not, and if you're getting output from each string at a consistent volume, then it would suggest the pickup is working. The ultra-high impedance of piezo pickups causes the tone you are describing if they are used without a pre-amp or with a faulty pre. It's worth checking that the mini-jack which connects the pickup to the pre is secure. Are you in the UK? I have a working pre from a 1612.
